Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit to AutoCAD export problem.
1 REPLY 1
494 Views, 1 Reply
Hi all,
Currently when I export Revit MEP file to Autocad, the duct fittings position seems to be changed. Its like someone has moved that object out of the place in autocad. Is there anything as such as co-ordinates which has got changed while exporting & that being the result of changed position of objects?
Please help me out.....
1 REPLY 1
rudi.roux
Hi @Anonymous,
Welcome to the community! Smiley Happy
There are a couple of things which you could try, this also resolves the issue when exporting from Revit to AutoCAD where some elements exported are missing.
  • The first thing which you can try is to set your Visual Style in Revit to Hidden Lines before exporting to AutoCAD. Also, refer to THIS POST.
  • Next, you could add any line style/pattern to ducts and fittings by means of creating a filter with defined rules to include ducts & fittings and mechanical equipment.
  • After doing one of the above-mentioned methods OR even both to make sure that everything exports correctly, export to DWG and then once you open the DWG file, just use the REGENALL command.
This should resolve your issue. I hope this helps! Smiley Happy
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
