Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit server connection problems
8 REPLIES 8
Message 1 of 9
drzepka1
2102 Views, 8 Replies
Hello everyone! I am a student and created my own Revit server for a collaborative school project. I Set up the the 2016 server with all the prerequisites, and the RSN.INI files are the same across the two machines. On my local network I can access my server, but when i am on a different network, and connected to the server through the accelerator, I can see the server, but can not access it to open or save files. Any help would be appreciated for this problem. Let me know if more information is needed. I checked the premissions and everything seems fine.
-Dylan
Here is my Local journal entry of the problem:
'E 01-Feb-2016 12:25:11.385; 0:<
Jrn.Command "StartupPage" , "Open an existing project , ID_REVIT_FILE_OPEN"
' 0:< ::8:: Delta VM: Avail -68 -> 134183033 MB, Used +4 -> 380 MB, Peak +3 -> 381 MB; RAM: Avail +3 -> 3751 MB, Used +12 -> 481 MB, Peak +9 -> 481 MB
' 0:< ModelPath Created: Is server path = True, Central server = "RevitServer", Path = ""
' 0:< Operation - RSEnterpriseClientInterop->listServerSubFoldersAndModels: SessionToken: User's Name Dylan, User's Machine Name DESKTOP-6LCES34, Operation GUID 61df44be-f3cd-4250-8b5c-b6254599710f
' 0:< Time: 2/1/2016 12:25:14:944 Calling: ListSubFoldersAndModels
' 0:< ::8:: Delta VM: Avail -3 -> 134183030 MB, Used +0 -> 381 MB; RAM: Avail +40 -> 3791 MB, Used +3 -> 484 MB, Peak +3 -> 484 MB
' 0:< Retry Count: 0 . Caught exception:
' 0:< Autodesk.RevitServer.Enterprise.Common.ClientServer.Helper.Exceptions.ProxyGenerationException: A problem occurred generating a proxy for the client action, Client Action = BasicAction, Target Node = RevitServer, Binding Name = tcpbuffer
' 0:< System.ServiceModel.EndpointNotFoundException: No DNS entries exist for host revitserver.
' 0:< System.Net.Sockets.SocketException: No such host is known
' 0:< Time: 2/1/2016 12:25:17:781 Calling: ListSubFoldersAndModels
' 0:< Retry Count: 1 . Caught exception:
' 0:< ModelPath Created: Is server path = True, Central server = "", Path = ""
'C 01-Feb-2016 12:25:20.079; 0:< Other Communication Exception while interacting with Revit Server. Please contact technical support.
' 0:< TaskDialog "This operation could not be completed. Please try again."
'Id : TaskDialog_Operation_Could_Not_Be_Completed
'CommonButtons : Close
8 REPLIES 8
Message 2 of 9
dzanta
in reply to: drzepka1
i would check any physical hardware firewalls installed on that other network.
i would check software firewalls on your computer and the server on that other network.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 9
drzepka1
in reply to: dzanta
I have disabled the firewall on the server, and on my workstation on the other network. Sadly this other network is a university network, and may have something to do with it. I will test from a coffee shop later to find out if it works from there.
Any other problems that could be causing this?
-Dylan
Message 4 of 9
dzanta
9 times out of 10, this is due to a firewall setting or hardware appliance that is blocking the communication.
Message 5 of 9
johan.cantryn
in reply to: dzanta
We've got the same problem but only on 1 workstation (out of 3).
These 3 workstation are directly connected to the host.
From the affected workstation:
We can ping the host.
Firewall exception is made for File and Printsharing
Port 80 and 808 are open
Latency and bandwith are ok
We can use the Revit Server admin tool to access the host
IDCM request are allowed to pass the firewall
System names are consistent between LAN and WAN
IP adresses are consistent between LAN and WAN
RSN.INI is present
Roles and Webservices on the server are installed and running
RevitServerAppPool and Autosync Service are Up and Running
IIS Default web site is started
Message 6 of 9
Hi Dylan,
Looks like a DNS problem.
Can you ping (or Tracert) the system with it's name (i.e. 'ping RevitServer')
If you can reach it with the ip-adress but not the name, you might be able to fix the issue by adding it to the host file on your system (C:\Windows\System32\drivers\etc\hosts)
Lars-Ake Johansson
Sr. SQA Engineer
Message 7 of 9
I fixed my problem. As it turns out, my RSN.ini file was wrong. I had the server's name in the file, but not the address of the server. Fixing this corrected my problem.
-Dylan
Message 8 of 9
OK,
Sound like a different solution to the same problem - unable to resolve the host with the DNS-name......
Good you found a way to fix it.
Lars-Ake Johansson
Sr. SQA Engineer
Message 9 of 9
I my case Revit 2015 UR1 was installed. Autodesk support confirmed me that there are Revit Server Issues with this build. See: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
They adviced me to install UR12 but in meantime we installed an older build an yes the problem was solved.
