Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit Server 2018 Problem
8 REPLIES 8
Message 1 of 9
jrobrador19
634 Views, 8 Replies
Hi guys,
I am using Windows Server 2008 R2 and I configured it for Revit Server 2018 by adding roles (Application Server and Web Server (IIS)) based on this link: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2017/...
On my client PC, I tried to collaborate a file within our network but when I try to save it at the server, this happens:
So I reviewed my set-up but I found no problems. So to test if my setup has a problem, I installed Revit Server 2017 on the server too. If the server is the problem, Revit Server 2017 should not work, but I was able to save files in the server without the error message appearing using Revit 2017.
Can you guys help me determine the problem? I'm willing to give you information to resolve this.
Jerous
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
8 REPLIES 8
Message 2 of 9
yurikim
in reply to: jrobrador19
On the server side, are you able to open Revit Server Administrator
Also check if RSN.ini file has been created correctly:
Also try going through the steps in the article:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Yuri Kim
Product Support Specialist, AEC
Message 3 of 9
jrobrador19
in reply to: yurikim
Yes, I am able to open the Revit Server Administrator (the one that runs in Internet Explorer with Silverlight) in the server. I properly placed the RSN.ini files with my server name written on it. I have also checked the log files but I have found nothing wrong.
Jerous Obrador
Message 4 of 9
yurikim
Do you see any errors in Server logs or journals from client machine?
Yuri Kim
Message 5 of 9
jrobrador19
Are there log files in the client computer side? If so, where could i check them?
Jerous Obrador
Message 6 of 9
yurikim
This is the location of the server logs (on server):
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
From user's machine, check journal files from here:
Yuri Kim
Message 7 of 9
jrobrador19
I just checked them and I think they're okay.
Jerous Obrador
Message 8 of 9
jrobrador19
I tried updating my Revit 2018 to 2018.2 but I'm still having problems. Any thoughts?
Jerous Obrador
Message 9 of 9
jrobrador19
@yurikim We can schedule a remote session so you can see the problem first hand.
Jerous Obrador
