Alright I'm at my wits end with Revit Server 2017. Here's what I've got:
- 3 Servers
- Windows 2012 running Revit Server 2014, 2015, 2016, 2017 (this is my company webserver)
- Windows 2012 hosting models for Revit Server 2014, 2015, 2016 (company domain controller)
- Windows 2008 running and hosting Revit Server 2014, 2014, 2015, 2016, 2017
Here's my problem: When I install Revit server 2017 on the webserver, and tell it I want to host the models on a network share (domain controller hosts all of our data) everything appears to install just fine. When I try to add folders to the admin console they add, and then if I try to rename them in the console it errors saying "An Unexpected error occurred". In the ModelService.Log I get ERROR TID(22) Unlockpathdoesnotexistexception. And i'm left with a bunch of "New Folder" and New Folder (<insert number here>)" folders in the console. Within Revit I can access the server, and view everything that's stored on the server (including all of the New folders) but I can't open any models from the server, and when I try to save a new model to the server I get the generic "Operation could not be completed" and the model does not save.
If I uninstall 2017 from the webserver, and then reinstall everything doing a default oob setup (including the model storage) on to the webserver it all works just fine.
RevitServerService user is setup and works just fine, and has since we started using Revit Server in 2014.
Permissions have all been set correctly on the 2017 shared folder.
There is nothing different about the 2017 installation from any of the previous version installations, it just doesn't work.
