Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit problem
6 REPLIES 6
burtg
409 Views, 6 Replies
Revit problem
I'm in need of some help. I currently a student at purdue and im in computer graphics class that needs REVIT. So since im student im allowed to access the programs for free to download to my laptop. So i downloaded it and im running into problems with it working properly. Everytime i try to open a file or save file or try to import something REVIT just freezes and doesn't do anything. It will sit and just stay like that for hours. I tried reinstalling it and repairing it and it still doesn't work . Below i have attached my computer specs and the screen it stay on and freezes. Any help would be appreciated so i can get it to work.
6 REPLIES 6
burtg
in reply to: burtg
burtg
in reply to: burtg
windows 10 PRO
INTEL CORE I7-6600U CPU
2.60GHZ 2.81GHZ
RAM 8 GB
64-BIT OPERATING SYSTEM, X64-BASED PROCESSOR
lars-ake.johansson
in reply to: burtg
Could you post one of your lats Revit journals here and I will see if I can figure out what's going on?
About Journal Files
Journals are named journal.####.txt
Regards
Lars-Ake Johansson
Sr. SQA Engineer
burtg
in reply to: lars-ake.johansson
HERE IS ONE OF THEM I BELIEVE
lars-ake.johansson
in reply to: burtg
Didn't see much from the journal but I can see that your system have dual graphics (Intel 520 and Nvidia GeForce).
Could you please verify that Revit is configured to use the GeForce graphics:
- Launch the Nvidia Control Panel
- Select "Manage 3D Settings"
- Select the "Program Settings" tab
- Select "Autodesk Revit" in the drop down "Select a program to customize"
- - If Revit is not in the list, select "Add" and browse to "C:\Program Files\Autodesk\Revit 2016" and select Revit.exe
- Make sure the "Select the preferred graphics..." is set to "High-performance NVIDIA"
Lars-Ake Johansson
Sr. SQA Engineer
burtg
I did that and made sure everything was correct. Still not working properly.
