Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
REVIT mesh for CFD Simulations
2 REPLIES 2
csjimenezEUDBR
229 Views, 2 Replies
Hi Everyone, I am working on CFD simulations and this requires the creation of a mesh based on the project's geometry. Usually the person in charge of the CFD simulation has to create the mesh from zero, and this is time consuming. I would like to take the Revit model and get the mesh directly from it. HAs anyone done anything like this? should I go through a DWG format to accomplish this? Thanks!
2 REPLIES 2
I'm curious if you ever received a response or got this figured out.
I just started learning CFD and having the correct geometry to mesh is a challenge at this point.
Tags (2)
HI, I actually didnt get a straight solution, the only way is to convert the CFD result to a FBX file
