Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit Linked models and guid
2 REPLIES 2
jkbi
616 Views, 2 Replies
When we use C4R / Design for Revit files are downloaded and worked on from …Revit versio\CollaborationCache\<hubid>\<projectid>. In that folder we have the hostmodels with GUID names, and a folder "LinkedModels" with the linked files as GUID names.
It seems link all Revit models have the same guid for both host models, live link, shared and consumed ?
Eg.
Setup:
HostA use live links for LiveLinkB, and consumed for ConsumedFileC
HostB use live links for LiveLinkA, and ConsumedFileC
HostC use shared links for SharedLinkA, and SharedLinkB
Opening with all links:
1) HostA loads into LinkedModels folder LiveLinkB, ConsumedFileC
2) HostB loads into LinkedModels folder LiveLinkA, and overwrites ConsumedFileC with ConsumedFileC
3) HostC loads into LinkedModels folder overwriting LiveLinkA with SharedLinkA, and  LiveLinkB with SharedLinkB.,
Not 100% sure on this, but seems like it is working like above?!
Labels (2)
2 REPLIES 2
Mohamed-Nassar
in reply to: jkbi
excuse me can clarify more to help you sir
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
jkbi
in reply to: Mohamed-Nassar
Well, maybe it was not so much a statement of a problem, but more an observation, that files are cached to the same folder by project, and not by host file. Meaning you may loose some of the benefits of caching links, and if you open files with closed workset and do not reload, you can end up with the wrong linked file versions.
