Revit for Collaboration issue with collaborating upload to a360
GPETTERSON
GPETTERSON
When I open the latestest version of the Architects work to collaborate (upload to the a360 site.  I have to do this because the Arch will not get on the site only contractor and engineer MEP team.  The Collaborate button only says "Collaborate" and not "Collaborate for 360"  It goes thru the motions but at the end it does not collaborate and post to A360 to be used as a sync link.  Last weeks version worked.  What is the issue?
GPETTERSON
Added this picture
KyleB_Autodesk
Sorry you're having an issue with this process.  I can't tell for certain from just the UI, but the Revit journal from the application session should indicate the point of failure.  Can you post it here please?
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
GPETTERSON
lars-ake.johansson
I believe that this is a known (and fixed) defect; Initialize Collaboration might fail when you are in a perpective view.
Could you switch to a 2D view and try again?
I this work, I strongly recommend that you update both Revit and Collaboration for Revit to the latest versions:
http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-a360-...
Regards
Lars-Ake Johansson
Sr. SQA Engineer
