Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit crashes
2 REPLIES 2
scottw
209 Views, 2 Replies
Revit crashes
I am getting a error message that saying Missing Content when I try to open a MEP model. Has anyone gotten this?Missing Elements.JPG
2 REPLIES 2
arjay.eco
in reply to: scottw
Hello @scottw
Have you tried auditing the project file during opening?
DanFaba
in reply to: scottw
Hey, Scott.
I took a look at your screenshot, and we have an article from the Autodesk Knowledge Network (AKN) that approaches said message.
The error could display in one of two forms (depending on the version of Revit you are working with), both of which I have attached a screenshot of, and there is a suggested solution included in the Help Pages from Autodesk. The suggested solution can be accessed also if you click this link
SUGGESTED SOLUTION
The error also derives from a different message that you may have seen at some point; "Data in File (filename).rvt is corrupt and needs to be manually recovered". The missing elements is a form of corruption that the file receives, which is why these two articles can be used to support the same situation.
The other suggested solution is for a Corrupted file, in another article from the AKN, which is in the link below:
OTHER SUGGESTED SOLUTION
Give them a try!
Dan Faba
Autodesk Revit Technical Support
