Revit Collaboration Local File is Corrupt
Message 1 of 23
"Data in file XXX - Cloud.rvt is corrupt and needs to be manually recovered. Please contact Autodesk Support."
I have contacted Autodesk Support, and they referred me to this forum. The above message is what I receive when I try to open my project.
I can open other projects from the same 360 Team folder, and my peers have no trouble with this file. I've also signed on to someone else's computer under my own 360 account and the file is fine, and I've tried repairing and reinstalling 360 Collab and Revit on my own computer, but no luck. I've followed these instructions as well: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
PLEASE HELP!!!
Replies (22)
Message 2 of 23
kevin.janik
We have had a couple instances where a computer's hard drive is almost full and we get that message since it can not load the model.
Message 3 of 23
Thanks, but I have 305 GB free space out of 463 GB.
Message 4 of 23
Message 5 of 23
lars-ake.johansson
Hi Francesca,
Could you post a Revit journal file from a session where you get this error - the journal might contain some more info on why this is happening.
Run Revit until you get the error and follow the instructions below to find the journal files
Journal-file
- Open up the Windows File Explorer (not Internet explorer)
- Go to C:\Users\Your login name
- If you see a folder here that is named ‘AppData’, open it.
If you don’t see ‘AppData’, go up to the address bar in explorer and click in it on an empty space
Type “\AppData” (without quotes) after the text that are already in there (e.g. making the entire path ‘C:\Users\[your login name]\AppData’) and press Enter
- Continue clicking down Local –Autodesk –Revit -Autodesk Revit [your Revit-‘flavor’] 2016[or your Revit version] - Journals
- In this folder you should see a lot of files named Journal.####.txt (where #### is a sequential number)
Post the txt-files with the highest number from this directory
(If you don’t see the journals here, try ‘Roaming’ instead of ‘Local’ in the path above.)
Lars-Ake Johansson
Sr. SQA Engineer
Message 6 of 23
' 0:< Initial VM: Avail 8388384 MB, Used 17 MB, Peak 45; RAM: Avail 12145 MB, Used 39 MB, Peak 45
'C 09-Mar-2016 10:31:17.996; 0:< started recording journal file
' Build: 20151207_1515(x64)
' Branch: RELEASE_2015_RTM
Dim Jrn
Set Jrn = CrsJournalScript
' 0:< ->desktop InitApplication
' 0:< <-desktop InitApplication
' 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Library=, Detail Library= (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -17 -> 8388367 MB, Used +2 -> 20 MB; RAM: Avail -3 -> 12143 MB, Used +5 -> 44 MB, Peak +5 -> 44 MB
'C 09-Mar-2016 10:31:18.034; 0:< License initialization complete
' 0:< ::0:: Delta VM: Avail -176 -> 8388192 MB, Used +42 -> 62 MB, Peak +24 -> 70 MB; RAM: Avail -51 -> 12092 MB, Used +57 -> 102 MB, Peak +57 -> 102 MB
' 0:< SystemSettings:
' 0:< 8=multiCoreCharacteristic
' 0:< true=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -759 -> 8387434 MB, Used +112 -> 175 MB, Peak +105 -> 175 MB; RAM: Avail -120 -> 11973 MB, Used +139 -> 242 MB, Peak +140 -> 242 MB
' 0:< Autodesk Revit 2015
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2015
' 0:< this journal = C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt
' 0:< ::0:: Delta VM: Avail -55 -> 8387379 MB, Used +8 -> 183 MB, Peak +39 -> 215 MB; RAM: Avail -26 -> 11947 MB, Used +20 -> 262 MB, Peak +25 -> 268 MB
' 0:< Added new API pushbutton 35011, name Navisworks 2016, class NavisWorks13.LcRevitExportCommand, assembly C:\Program Files\Common Files\Autodesk Shared\Navisworks\2016\nwexportrevit2015\nwexportrevit2015_13.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< Added new API pushbutton 35012, name Navisworks SwitchBack 2016, class NavisWorks13.LcActivateSwitchBack, assembly C:\Program Files\Common Files\Autodesk Shared\Navisworks\2016\nwexportrevit2015\nwexportrevit2015_13.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< Journal Init
' 0:< Log Summary
' 0:< .Count
' 0:< ...CloseHiddenWindowsInAllDocuments = 1
' 0:< ...DBG_SOMETHING = 1
' 0:< ...DBG_WARNING = 1
' 0:< ...onUpdateWindowCloseHidden = 1
' 0:< ...PendingMessages = 1
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 21
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 8
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< ...Global = 0 (Scalable)
' 0:< ...PoolGlobal = 1 (Pool)
' 0:< ...PoolLocking = 1 (Locking)
' 0:< ...PoolScalable = 1 (Pool)
' 0:< ...PoolTreeNodes = 0 (Allocator)
' 0:< ...Scalable = 0 (Scalable)
'H 09-Mar-2016 10:31:21.601; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=, Architectural Template=, Structural Template=, Mechanical Template="
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2015.000", "2.146"
Jrn.Directive "Username" _
, "francesca.alfajora@fme-arch.com"
Jrn.Directive "CategoryDisciplineFilter" _
, 3
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 1
Jrn.Directive "AllowPinnedSelection" _
, 0
' 0:< API_SUCCESS { Registered an external service.: ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96); VendorId(ADSK); Description(This service supports managing references to external resources such as Revit links or other referenced data.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2); VendorId(ADSK); Description(Navisworks Export Service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45); VendorId(ADSK); Description(Snapping Service Description) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143); VendorId(ADSK); Description(The external service to view and modify code checking parameter in analytical elements.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e); VendorId(ADSK); Description(The external service to view and modify service type parameter in structural elements.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); VendorId(ADSK); Description(IFC) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); Name(Default IFC); VendorId(ADSK); Description(Default IFC) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); VendorId(ADSK); Description(Duct fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); VendorId(ADSK); Description(Duct Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); VendorId(ADSK); Description(Pipe Straight Segment Pressure Drop Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(bf0da776-5307-4747-8285-f358e92a90d0); VendorId(ADSK); Description(Convert Fixture Units to Flow for Plumbing Fixtures, which is applicable to Domestic Water System Flow Calculation) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9); VendorId(ADSK); Description(This service supports custom handling of many UI operations related to external resources.) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); VendorId(ADSK); Description(Duct fitting and accessory pressure drop UI service) }
' 0:< API_SUCCESS { Registered an external service.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); VendorId(ADSK); Description(Pipe fitting and accessory pressure drop UI service) }
' 0:< ::0:: Delta VM: Avail -62 -> 8387318 MB, Used +23 -> 207 MB; RAM: Avail -26 -> 11922 MB, Used +30 -> 292 MB, Peak +24 -> 292 MB
' 0:< To make IFC server work.
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); Name(Revit Default DB Server); VendorId(ADSK); Description(Revit BuiltIn server for loading local resources.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(bf0da776-5307-4747-8285-f358e92a90d0); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); Name(Plumbing Fixture Flow); VendorId(ADSK); Description(Calculation of flow using the Plumbing Fixture Flow method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); ServerId(ea275fb1-5d7b-47d6-b828-bf856df9bfd5); Name(Simplified Colebrook Equation); VendorId(ADSK); Description(Calculation of pressure drop using Darcy-Weisbach method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); Name(Altshul-Tsal Equation); VendorId(ADSK); Description(Calculation of duct pressure drop using Darcy method.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); Name(Haaland Equation); VendorId(USERADDIN); Description(Computes Friction Factor using the Haaland Equation.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); Name(Haaland Equation); VendorId(USERADDIN); Description(Computes Friction Factor using the Haaland Equation.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); Name(Colebrook Equation); VendorId(USERADDIN); Description(Computes Friction Factor using Colebrook Equation.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); Name(Colebrook Equation); VendorId(USERADDIN); Description(Computes Friction Factor using Colebrook Equation.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); Name(Not Defined); VendorId(ADSK); Description(The Pressure Drop on the fitting will be treated as 0.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); Name(Coefficient from ASHRAE Table); VendorId(ADSK); Description(Version 5.0.0 of the ASHRAE duct fitting database has been implemented for duct fittings. When using this calculation method, the duct fitting coefficient will be read from the mapped ASHRAE table.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); Name(Specific Coefficient); VendorId(ADSK); Description(Customize the Loss Coefficient on the fitting, then using the following method to calculate duct fitting pressure drop. this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); Name(Specific Loss); VendorId(ADSK); Description(Customize the Pressure Drop on the fitting, this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); Name(Not Defined); VendorId(ADSK); Description(The Pressure Drop on the fitting will be treated as 0.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); Name(K Coefficient from Table); VendorId(ADSK); Description(CIBSE/ASHRAE/Crane standards are used for pipe fitting loss definition based on the pipe fitting types.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); Name(Specific Coefficient); VendorId(ADSK); Description(Customize the Loss Coefficient on the fitting, then using the following method to calculate pipe fitting pressure drop. This method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); Name(Specific Loss); VendorId(ADSK); Description(Customize the Pressure Drop on the fitting, this method only available for two connector fittings, like elbow, transitions, etc.) }
' 0:< API registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< API registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< API registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< API registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< ::0:: Delta VM: Avail -12 -> 8387307 MB, Used +3 -> 210 MB; RAM: Avail -9 -> 11913 MB, Used +9 -> 302 MB, Peak +10 -> 303 MB
' 0:< API registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408).
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API External Application added: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Assembly: RaaSApplication.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
'H 09-Mar-2016 10:31:22.861; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { API External Application added: AutoLoad, Class: AutoLoader.AutoLoader, Assembly: AutoLoader.dll, VendorId: ADSK, Description: . }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(607992d7-359d-4593-b497-8aa238e2c564); Name(Duct not defined pressure drop UI server); VendorId(ADSK); Description(Duct not defined pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); Description(Duct specific coefficient pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); Name(Duct specific loss pressure drop UI server); VendorId(ADSK); Description(Duct specific loss pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(52009bda-c817-4aef-aa31-36dc3742516e); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); Description(Duct coefficient from table pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); Name(Pipe not defined pressure drop UI server); VendorId(ADSK); Description(Pipe not defined pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); Description(Pipe specific coefficient pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); Description(Pipe specific loss pressure drop UI server) }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); Description(Pipe K coefficient from table pressure drop UI server) }
' 0:< API_SUCCESS { API External Application added: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Assembly: FittingAndAccessoryCalculationUIServers.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); Name(Revit Default UI Server.); VendorId(ADSK); Description(Handles user interface operations related to Revit builtIn DB server for local resources.) }
' 0:< API_SUCCESS { API External Application added: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Assembly: KeynoteUIServer.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { API External Application added: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Assembly: ObjectNumberingUI.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2015\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API External Application added: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Assembly: PressureLossReport.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); Name(SectionTypeParameterServer); VendorId(ADSK); Description(Provides implementation for Section Type parameters) }
' 0:< API_SUCCESS { API External Application added: Structural Section Properties, Class: SectionPropertiesServerDB.ServerApp, Assembly: SectionPropertiesServerDB.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9).
' 0:< API registering CloudSharedLocalIncompatible event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9).
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { API External Application added: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\Collaborate.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command A360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { API External Application added: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\CollaborateBrowser.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< ::0:: Delta VM: Avail -11 -> 8387296 MB, Used -9 -> 202 MB; RAM: Avail +1 -> 11915 MB, Used +1 -> 303 MB
'C 09-Mar-2016 10:31:23.233; 0:< Loading bcg.dll: Autodesk.Bcg, Version=1.7.3.0, Culture=neutral, PublicKeyToken=d672471c03b2c408
'C 09-Mar-2016 10:31:23.339; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { API External Application added: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Assembly: C:\Program Files\Autodesk\A360 Collaboration for Revit 2015\SkyscraperClientHost.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< Added new API pushbutton 6400 name text Glue class BIM360RevitAddin.GlueItCommand assembly C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\BIM360GlueRevit2015Addin.dll
' 0:< Added new API pushbutton 6401 name text Clash
'Pinpoint class BIM360RevitAddin.GluePinPointCommand assembly C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\BIM360GlueRevit2015Addin.dll
' 0:< Added new API pushbutton 6402 name text Equipment
'Properties class BIM360RevitAddin.EquipmentCommand assembly C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\BIM360GlueRevit2015Addin.dll
' 0:< API registering ApplicationInitialized event by application Ribbon (603a4c35-f8a1-4b4e-8ae3-d55ee114027d).
' 0:< API registering ApplicationClosing event by application Ribbon (603a4c35-f8a1-4b4e-8ae3-d55ee114027d).
' 0:< API_SUCCESS { API External Application added: Ribbon, Class: BIM360RevitAddin.HorizontalRibbon, Assembly: C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\BIM360GlueRevit2015Addin.dll, VendorId: BIM360, Description: Autodesk, Inc, www.autodesk.com. }
' 0:< API registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2015\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2015\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { API External Application added: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Assembly: Communicator\SmartMonkey.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
'H 09-Mar-2016 10:31:23.726; 0:<
, "1.OnIdleTask"
' 0:< API registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< API registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< API registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< API registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< API registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< API registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b).
' 0:< Added new API pushbutton 6403 name text Dynamo 0.8 class Dynamo.Applications.DynamoRevit assembly C:\Program Files\Dynamo 0.8\Revit_2015\DynamoRevitDS.dll
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { API External Application added: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Assembly: C:\Program Files\Dynamo 0.8\Revit_2015\DynamoRevitVersionSelector.dll, VendorId: ADSK, Description: Dynamo. }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2015\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2015\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Views For A360 CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { API External Application added: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< ::0:: Delta VM: Avail -25 -> 8387271 MB, Used +6 -> 209 MB, Peak +1 -> 217 MB; RAM: Avail -5 -> 11911 MB, Used +10 -> 313 MB, Peak +10 -> 313 MB
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' Executed implementation with implementation from application 'File exporter for Navisworks 2016' dll 'C:\Program Files\Common Files\Autodesk Shared\Navisworks\2016\nwexportrevit2015\nwexportrevit2015_13.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application File exporter for Navisworks 2016 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_NAVISWORKS' CanExecute implementation with implementation from application 'File exporter for Navisworks 2016' dll 'C:\Program Files\Common Files\Autodesk Shared\Navisworks\2016\nwexportrevit2015\nwexportrevit2015_13.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application File exporter for Navisworks 2016 (280bb447-f630-48b0-99be-6a776ac7b5c8). }
' 0:< API_SUCCESS { An external server has been registered.: ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2); ServerId(68e1934c-ec3b-410c-8c82-434f0cf25446); Name(Navisworks 2016); VendorId(Autodesk Navisworks); Description(Autodesk Navisworks Exporters 2016) }
' 0:< API_SUCCESS { API External Application added: File exporter for Navisworks 2016, Class: NavisWorks13.LcRevitExportApplication, Assembly: C:\Program Files\Common Files\Autodesk Shared\Navisworks\2016\nwexportrevit2015\nwexportrevit2015_13.dll, VendorId: ADSK, Description: Autodesk, www.autodesk.com. }
' 0:< ::0:: Delta VM: Avail -2 -> 8387270 MB, Used +5 -> 214 MB, Peak +4 -> 221 MB; RAM: Avail -7 -> 11905 MB, Used +5 -> 319 MB, Peak +12 -> 326 MB
'C 09-Mar-2016 10:31:24.196; 0:< ->processShellCommand
'E 09-Mar-2016 10:31:24.196; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -100 -> 8387170 MB, Used +38 -> 253 MB, Peak +32 -> 253 MB; RAM: Avail -27 -> 11878 MB, Used +32 -> 351 MB, Peak +25 -> 351 MB
'C 09-Mar-2016 10:31:24.361; 0:< <-processShellCommand
' 0:< ->DesktopMFCApp::doStartupWarnings
'C 09-Mar-2016 10:31:24.361; 0:< manage licensing
' 0:< License mode: Network
' 0:< Server: fme-dc-02
' 0:< Status: Network licensing connection is established.
' 0:< Type: Network
' 0:< Usage: Commercial
' 0:< Behavior: Permanent
' 0:< Expiration: None
'C 09-Mar-2016 10:31:24.512; 0:< manage involvement
' 0:< ::1:: Delta VM: Avail -2124 -> 8385047 MB, Used +8 -> 262 MB, Peak +8 -> 262 MB; RAM: Avail -13 -> 11865 MB, Used +14 -> 365 MB, Peak +14 -> 365 MB
'C 09-Mar-2016 10:31:24.742; 0:< manage debug modes
'C 09-Mar-2016 10:31:24.742; 0:< MFCApp::testGraphicsHardware
' 0:< ::1:: Delta VM: Avail -37 -> 8385011 MB, Used +1 -> 263 MB, Peak +1 -> 264 MB; RAM: Avail -6 -> 11860 MB, Used +5 -> 371 MB, Peak +5 -> 371 MB
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:< ::1:: Delta VM: Avail -61 -> 8384950 MB, Used +43 -> 307 MB, Peak +44 -> 308 MB; RAM: Avail -12 -> 11848 MB, Used +13 -> 384 MB, Peak +13 -> 384 MB
' 1:< DX Device: DirectX 11, Hardware
'C 09-Mar-2016 10:31:24.786; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -16 -> 8384934 MB, Used +5 -> 313 MB, Peak +9 -> 318 MB; RAM: Avail -11 -> 11837 MB, Used +5 -> 389 MB, Peak +10 -> 395 MB
' 1:<
'Current driver version: 14.502.1005.0
'Certified driver(s): 13.352.1009.0
' 1:< VIDEO CARD ENVIRONMENT: CARD="AMD FirePro W2100 (FireGL V) Graphics Adapter" ManufacturerID="1002" DeviceID="6608" osID="2000" DRIVER="14.502.1005.0" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 09-Mar-2016 10:31:24.845; 1:< FINISH video card certification
' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=y
'CardIsNotListed=n
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 09-Mar-2016 10:31:24.845; 0:< MFCApp::testMSAA
'C 09-Mar-2016 10:31:24.845; 0:< postConditionalWarnings
'C 09-Mar-2016 10:31:24.845; 0:< giveAtomRegistrationWarnings
'C 09-Mar-2016 10:31:24.845; 0:< warnings->consumeAll
' 0:< TaskDialog "The path you have specified for the default family template files is invalid."
'Id : TaskDialog_Default_Family_Template_File_Invalid
'CommonButtons : Close
'DefaultButton : Close
' 0:< ::1:: Delta VM: Avail -38 -> 8384897 MB, Used +13 -> 326 MB, Peak +10 -> 328 MB; RAM: Avail -35 -> 11803 MB, Used +24 -> 414 MB, Peak +20 -> 415 MB
'C 09-Mar-2016 10:31:37.728; 0:< Process result of DebugModes-Changed Task Dialog
'C 09-Mar-2016 10:31:37.728; 0:< isMaterialLibraryAvailable
'C 09-Mar-2016 10:31:37.728; 0:< start up warnings for AddIns
' 0:< <-DesktopMFCApp::doStartupWarnings
' 0:< <-desktop InitNativeInstance
' 0:< ->desktop InitManagedInstance
' 1:< API registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 1:< API registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 1:< API registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< <-desktop InitManagedInstance
'C 09-Mar-2016 10:31:37.887; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 7601
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 7 Professional
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< CSDVersion : Service Pack 1
' 0:< FreePhysicalMemory : 12080976
' 0:< FreeSpaceInPagingFiles : 16644048
' 0:< FreeVirtualMemory : 28351764
' 0:< MaxProcessMemorySize : 8589934464
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 1
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 33433788
' 0:< TotalVisibleMemorySize : 16717812
' 0:< Version : 6.1.7601
' 0:< Process affinity mask : FF
' 0:< System affinity mask : FF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 60 Stepping 3
' 0:< CurrentClockSpeed : 3601
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 60 Stepping 3
' 0:< Family : 198
' 0:< L2CacheSize : 1024
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3601
' 0:< Name : Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
' 0:< ProcessorType : 3
' 0:< Revision : 15363
' 0:< Role : CPU
' 0:< SocketDesignation : SOCKET 0
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : Advanced Micro Devices, Inc.
' 0:< AdapterDACType : Internal DAC(400MHz)
' 0:< AdapterRAM : -2147483648
' 0:< Caption : AMD FirePro W2100 (FireGL V) Graphics Adapter
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1920
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 1080
' 0:< Description : AMD FirePro W2100 (FireGL V) Graphics Adapter
' 0:< DriverDate : 20150126000000.000000-000
' 0:< DriverVersion : 14.502.1005.0
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 59
' 0:< Monochrome : 0
' 0:< Name : AMD FirePro W2100 (FireGL V) Graphics Adapter
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1920 x 1080 x 4294967296 colors
' 0:< VideoProcessor : AMD Radeon Graphics Processor (0x6608)
' 0:< MaxRefreshRate : 0
' 0:< ::1:: Delta VM: Avail -4 -> 8384894 MB, Used +2 -> 329 MB, Peak +2 -> 330 MB; RAM: Avail -12 -> 11791 MB, Used +6 -> 421 MB, Peak +5 -> 421 MB
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2010
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2010
' 0:< Direct : 0
' 0:< DriverName : Send To Microsoft OneNote 2010 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2010
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : XPSPort:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : Bluebeam PDF
' 0:< Default : 0
' 0:< DeviceID : Bluebeam PDF
' 0:< Direct : 0
' 0:< DriverName : BluebeamPSDriver
' 0:< Local : -1
' 0:< Name : Bluebeam PDF
' 0:< Network : 0
' 0:< PortName : BLUEBEAMPDFPORT
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Adobe PDF
' 0:< Default : 0
' 0:< DeviceID : Adobe PDF
' 0:< Direct : 0
' 0:< DriverName : Adobe PDF Converter
' 0:< HorizontalResolution : 1200
' 0:< Local : -1
' 0:< Name : Adobe PDF
' 0:< Network : 0
' 0:< PortName : Documents\*.pdf
' 0:< RawOnly : -1
' 0:< Shared : 0
' 0:< VerticalResolution : 1200
' 0:< Caption : \\fme-print-01\Xerox WorkCentre 7545 PCL6
' 0:< Default : -1
' 0:< DeviceID : \\fme-print-01\Xerox WorkCentre 7545 PCL6
' 0:< Direct : 0
' 0:< DriverName : Xerox WorkCentre 7545 PCL6
' 0:< Local : 0
' 0:< Name : \\fme-print-01\Xerox WorkCentre 7545 PCL6
' 0:< Network : -1
' 0:< PortName : IP_192.168.0.251
' 0:< PrintProcessor : mptprntproc.dll
' 0:< RawOnly : -1
' 0:< Shared : -1
' 0:< Caption : \\fme-print-01\Oce PlotWave 300
' 0:< Default : 0
' 0:< DeviceID : \\fme-print-01\Oce PlotWave 300
' 0:< Direct : 0
' 0:< DriverName : Oce PlotWave 300
' 0:< Local : 0
' 0:< Name : \\fme-print-01\Oce PlotWave 300
' 0:< Network : -1
' 0:< PortName : IP_192.168.0.10
' 0:< RawOnly : -1
' 0:< Shared : -1
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2010
' 0:< DriverVersion : 1536
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Duplex : 0
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Bluebeam PDF
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Adobe PDF
' 0:< PrintQuality : 1200
' 0:< XResolution : 1200
' 0:< YResolution : 1200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : \\fme-print-01\Xerox WorkCentre 7545 PCL6
' 0:< Duplex : -1
' 0:< MediaType : 1
' 0:< Color : 1
' 0:< Copies : 1
' 0:< Description : \\fme-print-01\Oce PlotWave 300
' 0:< PaperLength : 11176
' 0:< PaperSize : UNKNOWN
' 0:< PaperWidth : 8636
'E 09-Mar-2016 10:31:39.807; 0:<
Jrn.AppButtonEvent 1 , "Application Menu is opening"
'E 09-Mar-2016 10:31:40.778; 0:<
Jrn.AppButtonEvent 0 , "Application Menu is closing"
'E 09-Mar-2016 10:31:40.798; 0:<
Jrn.Command "Internal" , "Open an existing project , ID_REVIT_FILE_OPEN"
' 0:< ::4:: Delta VM: Avail -38 -> 8384856 MB, Used +7 -> 337 MB, Peak +6 -> 337 MB; RAM: Avail -10 -> 11782 MB, Used +13 -> 434 MB, Peak +13 -> 435 MB
' 0:< logIntoA360 - starting to check and enforce A360 login.
' 0:< ::4:: Delta VM: Avail -24 -> 8384832 MB, Used +4 -> 341 MB, Peak +4 -> 341 MB; RAM: Avail -6 -> 11777 MB, Used +8 -> 443 MB, Peak +7 -> 443 MB
'H 09-Mar-2016 10:31:50.619; 0:<
Jrn.Data "File Name" _
, "IDOK", "CLD://{fb36b3dc-9dbd-4c87-9311-84027589a2a5}100-150 Hooper FME/{4c8c3250-f7c1-4e79-8845-d4a66aac5307}2015072 100 Hooper - Cloud.rvt"
' 0:< Operation - ServerModelAccessProvider::IsUpToDate: ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID f2d59c2c-5a70-4c44-99e8-677c335e522f, Central server = "model15.skyscraper.autodesk.com", Path = "CLD:\\{fb36b3dc-9dbd-4c87-9311-84027589a2a5}100-150 Hooper FME\{4c8c3250-f7c1-4e79-8845-d4a66aac5307}2015072 100 Hooper - Cloud.rvt",
' 0:< ::4:: Delta VM: Avail -41 -> 8384791 MB, Used +8 -> 349 MB, Peak +8 -> 349 MB; RAM: Avail -3 -> 11775 MB, Used +6 -> 449 MB, Peak +6 -> 449 MB
' 0:< Time: 3/9/2016 10:31:51:518 Calling: IsUpToDate
' 0:< Time: 3/9/2016 10:31:52:442 Returned from: IsUpToDate
' 0:< getOptionForOpenCloudModel: the cached local model "A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt" is out-of-date and will be recreated.
' 0:< createNewLocal: starting to create a new local file from "A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt".
' 0:< Connecting session [$d8e8056e] to Worksharing Log [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt]
' 0:< Additional IP address/name found for host FME-T1700-04: 192.168.0.116
' 0:< SLOG $d8e8056e 2016-03-09 10:31:53.201 >Session $d8e8056e
' 0:< SLOG user="francesca.alfajora@fme-arch.com"
' 0:< SLOG build="2015 20151207_1515(x64)"
' 0:< SLOG journal="C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt"
' 0:< SLOG host=fe80::1826:931c:16cb:30a9%11 "FME-T1700-04.fme-arch.net"
' 0:< SLOG server=fe80::1826:931c:16cb:30a9%11 "FME-T1700-04.fme-arch.net"
' 0:< SLOG central="CLD:\\{fb36b3dc-9dbd-4c87-9311-84027589a2a5}100-150 Hooper FME\{4c8c3250-f7c1-4e79-8845-d4a66aac5307}2015072 100 Hooper - Cloud.rvt"
' 0:< SLOG local="C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt"
' 0:< SLOG timer="pulse-d8e8056e.tmp"
' 0:< SLOG timebias=480
' 0:< SLOG $d8e8056e 2016-03-09 10:31:53.201 >CutLocal
' 0:< Time: 3/9/2016 10:31:53:210 Calling: IdentifyModel
' 0:< Time: 3/9/2016 10:31:53:620 Returned from: IdentifyModel
' 0:< Operation - ModelDataFormatVersion: ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 4a4f0a3c-d723-4028-837b-0ba433497b01, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Time: 3/9/2016 10:31:53:623 Calling: ModelDataFormatVersion
' 0:< Time: 3/9/2016 10:31:53:965 Returned from: ModelDataFormatVersion
' 0:< logAnalyticsRequest_
' 0:< Keys Count: 14
'C 09-Mar-2016 10:31:54.004; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'api_category: Analytics
'context_call: Pre-check cache
'context_job: Model Open
'duration: 23
'facets_included: skybase, skyclient
'skybase_correlation_id: 5cadea7d-179d-482c-a9ba-55d568127629
'skybase_model_guid: 4c8c3250-f7c1-4e79-8845-d4a66aac5307
'skybase_model_size_bytes: 518139904
'skybase_project_guid: fb36b3dc-9dbd-4c87-9311-84027589a2a5
'skybase_version: 1.0.0
'skyclient_element_count: N.A.
'skyclient_model_delta: N.A.
'skyclient_version: 1.0.0
'status: ok
Message 7 of 23
' 0:< Operation - BeginReadData&colon; ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 178b3b28-9a53-4a9a-970c-1bf4a3c6c054, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Operation - PatientOperationRetryAlgo.retryMethod: SessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 70dff700-9f15-4e71-9b13-facecffe7030
' 0:< ModelPath Created: Is server path = True, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt"
' 0:< Time: 3/9/2016 10:31:54:120 Calling: BeginReadData
' 0:< Time: 3/9/2016 10:31:54:659 Returned from: BeginReadData
' 0:< Miss Model Version ModelVersion(Version > Major:-1, Minor:1 : HistoryCheckInfo > ModelHistoryCheckInfo(LatestEpisodeGuid > EpisodeGuidGUID8d02c516-8d8d-410d-9806-a5183417bff8, ClientModelGuid > GUID00000000-0000-0000-0000-000000000000)) in PAC cache.
' 0:< Miss Model Version ModelVersion(Version > Major:-1, Minor:1597 : HistoryCheckInfo > ModelHistoryCheckInfo(LatestEpisodeGuid > EpisodeGuidGUID3a54d24a-6ec3-418c-ad34-565ee6081f8b, ClientModelGuid > GUID00000000-0000-0000-0000-000000000000)) in PAC cache.
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=Formats, number=0), Revision=1): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID accd1230-e39f-4985-a546-7950f5d25d61, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache miss [formats.0637.dat]
' 0:< Time: 3/9/2016 10:31:54:702 Calling: GetDataURI
' 0:< Starting GetDataURI of ModelDataResourceInfo(ModelResourceId(type=Formats, number=0), Revision=1)
' 0:< Ended GetDataURI of ModelDataResourceInfo(ModelResourceId(type=Formats, number=0), Revision=1)
' 0:< Time: 3/9/2016 10:31:55:065 Returned from: GetDataURI
'C 09-Mar-2016 10:31:55.307; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: PAC cache miss
'duration: 612
'skyclient_model_delta: 134025
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=First, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 07e8e324-6fab-44e7-982f-f759da42795d, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\global.4272.dat]
'C 09-Mar-2016 10:31:55.313; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: PAC cache hit
'duration: 1
'skybase_model_size_bytes: 636625
'skyclient_model_delta: 0
'status: ok
'C 09-Mar-2016 10:31:55.316; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 1
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=HistoryTable, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 0ef10fc9-8c64-4dd7-8196-d4fd28e679e2, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\history.4272.dat]
'C 09-Mar-2016 10:31:55.321; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 112586
'status: ok
'C 09-Mar-2016 10:31:55.323; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ElementTable, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 013634d4-fd36-4f5c-82b6-18e2787f4b5e, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\elemtable.4272.dat]
'C 09-Mar-2016 10:31:55.330; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 2
'skybase_model_size_bytes: 3301599
'status: ok
'C 09-Mar-2016 10:31:55.332; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 2
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ContentDocuments, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 062fff8a-3d2a-4663-a684-13e51ecf60e1, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\contentdocuments.3659.dat]
'C 09-Mar-2016 10:31:55.342; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 2
'skybase_model_size_bytes: 2962049
'status: ok
'C 09-Mar-2016 10:31:55.344; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 2
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=WorksetTable, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID dcd575c7-ee27-4074-9cba-c0c186eed807, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\partitiontable.4272.dat]
'C 09-Mar-2016 10:31:55.349; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 299634
'status: ok
'C 09-Mar-2016 10:31:55.351; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=IncrementTable, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 99439627-7be1-40d9-b3b7-f08539d001c5, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\incrementtable.4290.dat]
'C 09-Mar-2016 10:31:55.356; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 149689
'status: ok
'C 09-Mar-2016 10:31:55.358; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=Contents, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 1b372eaa-3bdc-4560-bbfc-2f4ad2045cbb, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\contents.1597.dat]
'C 09-Mar-2016 10:31:55.362; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 204181
'status: ok
'C 09-Mar-2016 10:31:55.365; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=Preview, number=0), Revision=939): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID b338b292-e1be-4ac2-861d-300f04912cf6, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\preview.2511.dat]
'C 09-Mar-2016 10:31:55.369; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 1804
'status: ok
'C 09-Mar-2016 10:31:55.371; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=BasicFileInfo, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID b60542dc-dfe2-4cd6-8f75-398a5faf8309, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\basicfileinfo.4134.dat]
'C 09-Mar-2016 10:31:55.375; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 2186
'status: ok
'C 09-Mar-2016 10:31:55.378; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=TransmissionData, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 47c5518a-368c-48d3-bccd-653718e25679, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\transmissiondata.3659.dat]
'C 09-Mar-2016 10:31:55.382; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 18772
'status: ok
'C 09-Mar-2016 10:31:55.384; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ProjectInformation, number=0), Revision=1597): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 226ada04-9dad-4f89-adee-288255d20886, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\projectinformation.3594.dat]
'C 09-Mar-2016 10:31:55.389; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 1374
'status: ok
'C 09-Mar-2016 10:31:55.391; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ElementStream, number=102), Revision=6): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID ecced1ad-460a-4b40-bc1f-be9c8b14f5ac, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\102_4.rws]
'C 09-Mar-2016 10:31:55.395; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 6281
'status: ok
'C 09-Mar-2016 10:31:55.398; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< Operation - ReadData - ModelDataResourceInfo(ModelResourceId(type=ElementStream, number=1596), Revision=1): ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID 7ebc60bb-045d-42e4-978c-fb6029b589c0, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Cache hit [C:\Users\f_a\AppData\Local\Autodesk\Revit\PacCache\4c8c3250-f7c1-4e79-8845-d4a66aac5307\3a54d24a-6ec3-418c-ad34-565ee6081f8b\1596_41.rws]
'C 09-Mar-2016 10:31:55.402; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'skybase_model_size_bytes: 21750
'status: ok
'C 09-Mar-2016 10:31:55.404; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'duration: 0
'status: ok
' 0:< ::4:: Delta VM: Avail -2 -> 8384790 MB, Used +7 -> 357 MB, Peak +8 -> 358 MB; RAM: Avail -6 -> 11769 MB, Used +13 -> 462 MB, Peak +13 -> 463 MB
' 0:< Operation - EndReadData&colon; ModelSessionToken: User's Name francesca.alfajora@fme-arch.com, User's Machine Name FME-T1700-04, Operation GUID d3615989-2ad8-4181-aea6-4027fbe92e8b, Central server = "model15.skyscraper.autodesk.com", Path = "2015072 100 Hooper - Cloud.rvt",
' 0:< Time: 3/9/2016 10:31:55:407 Calling: EndReadData
' 0:< Time: 3/9/2016 10:31:55:811 Returned from: EndReadData
'C 09-Mar-2016 10:31:55.811; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: Download Resources
'duration: 1716
'status: ok
' 0:< Dumped directory: C:\Users\f_a\AppData\Local\Temp\Revit_ModelDataFileDownload_08fb883c5e11474d93ef392b9a69c89f and its contents.
'C 09-Mar-2016 10:31:56.310; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: Generate RVT from downloaded resources
'duration: 496
'status: ok
'C 09-Mar-2016 10:31:56.312; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: Refresh cached central file
'duration: 3104
'status: ok
' 0:< ::4:: Delta VM: Avail -5 -> 8384785 MB, Used +1 -> 358 MB, Peak +2 -> 360 MB; RAM: Avail -493 -> 11276 MB, Used +2 -> 464 MB, Peak +9 -> 472 MB
' 0:< SLOG $d8e8056e 2016-03-09 10:31:56.560 <CutLocal
' 0:< SLOG $d8e8056e 2016-03-09 10:31:56.560 <Session
' 0:< createNewLocal: finished creating the new local file from "A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt".
'H 09-Mar-2016 10:31:56.560; 0:<
Jrn.Data "WorksetConfig" _
, "Custom", 0
'C 09-Mar-2016 10:31:56.563; 0:< SkyscraperClientHost.LogAnalyticsRequest: AnalyticsProperties:
'context_call: File Open Menu: doesn't include Links and UI
'duration: 5944
'status: ok
' 1:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 1:< RAM Statistics: 11276 / 16325 465=InUse 472=Peak
' 1:< VM Statistics: 8384785 / 8388607 358=InUse 360=Peak
' 2:< API_SUCCESS { An external server has been registered.: ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96); ServerId(d2c3617d-7a16-45bc-b395-44897852f485); Name(A360); VendorId(ADSK); Description(This server is the A360 Resource Server.) }
' 2:< File: Open
' 3:< Connecting session [$b4544c56] to Worksharing Log [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt]
' 0.000009 4:<<<WorksharingLog::getSlog []
' 3:< Additional IP address/name found for host FME-T1700-04: 192.168.0.116
' 3:< ::4:: Delta VM: Avail -990 -> 8383796 MB, Used +2 -> 361 MB, Peak +0 -> 361 MB; RAM: Avail -9 -> 11268 MB, Used +1 -> 465 MB
' 0.001137 4:<<acquireFileLock
' 0.001779 3:<<OpenDocumentTask::acquireFileLock
' 0.014380 6:<<<loadAllClasses
' 0.000051 6:<<<RegisterPreDocLoadCallback::invokeCallbacks
' 0.002983 7:<<<LoadModel DSI
' 6:< Server-based Central Model [identity = 4c8c3250-f7c1-4e79-8845-d4a66aac5307, path = "A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt"]: init
' 7:< Connecting session [$b2f28696] to Worksharing Log [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt]
' 0.000015 8:<<<WorksharingLog::getSlog [CLD:\\{fb36b3dc-9dbd-4c87-9311-84027589a2a5}100-150 Hooper FME\{4c8c3250-f7c1-4e79-8845-d4a66aac5307}2015072 100 Hooper - Cloud.rvt]
' 7:< Additional IP address/name found for host FME-T1700-04: 192.168.0.116
' 7:< SLOG $b2f28696 2016-03-09 10:31:56.619 >Session $b2f28696
' 7:< SLOG user="francesca.alfajora@fme-arch.com"
' 7:< SLOG build="2015 20151207_1515(x64)"
' 7:< SLOG journal="C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt"
' 7:< SLOG host=fe80::1826:931c:16cb:30a9%11 "FME-T1700-04.fme-arch.net"
' 7:< SLOG server=fe80::1826:931c:16cb:30a9%11 "FME-T1700-04.fme-arch.net"
' 7:< SLOG central="CLD:\\{fb36b3dc-9dbd-4c87-9311-84027589a2a5}100-150 Hooper FME\{4c8c3250-f7c1-4e79-8845-d4a66aac5307}2015072 100 Hooper - Cloud.rvt"
' 7:< SLOG local="C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt"
' 7:< SLOG timer="pulse-b2f28696.tmp"
' 7:< SLOG timebias=480
' 0.000085 8:<<<fileExists?
' 8:< DBG_INFO: No pDocumentStorage so cloud models may show GUIDs in UI.: line 636 of d:\ship\2015_px64\source\revit\revitdb\modelstorage\PatientStorage.cpp.
' 8:< SLOG $b2f28696 2016-03-09 10:31:56.620 .LockUsers R SCODE=0x80030003
' 0.000080 9:<<<fileExists?
' 0.000475 8:<<acquirePermissionsLocks
' 0.001279 7:<<lockPermissionsFilesForLoadSerialize
' 8:< SLOG $b2f28696 2016-03-09 10:31:56.621 .LockUsers RW locked
' 0.000065 9:<<<fileExists?
' 0.003561 8:<<acquirePermissionsLocks
' 0.003606 7:<<lockPermissionsFilesForLoadSerialize
' 7:< [TKY] readUT file is dummy
' 7:< [TKY] readER file is dummy
' 7:< EP::readDeltas 0 to 0 ignored; caller said refreshAllElements
' 8:< [TKY] readEP file is dummy
' 0.000036--------- 8:<<<EP::readEP [-2]
' 7:< [TKY] readWorksetCheckouts file is dummy
' 0.000280 7:<<DSI::loadPermissionsFiles
' 6:< DSI::loadPermissionsFiles error
' 6:< [TKY] loadPermissionsFiles erasedUT 0, erasedEP 0, erasedWC 0, erasedER 0
' 0.008578 6:<<loading DocumentStorageIndex
' 5:< SLOG $b2f28696 2016-03-09 10:31:56.624 >Open
' 0.000044 6:<<<fileExists?
' 5:< SLOG $b2f28696 2016-03-09 10:31:56.624 >Open:Local "C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt"
' 0.000053 6:<<<fileExists?
' 5:< fileSizeOnOpen:505996KB
'E 09-Mar-2016 10:31:56.647; 6:<
' [Jrn.BasicFileInfo] Rvt.Attr.Worksharing: In progress Rvt.Attr.UserName: Rvt.Attr.CentralModelPath: A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt Rvt.Attr.RevitBuildVersion: Autodesk Revit 2015 (Build: 20151007_1515(x64)) Rvt.Attr.LastSavePath: A360://100-150 Hooper FME/2015072 100 Hooper - Cloud.rvt Rvt.Attr.ProjectSpark: notProjectSpark Rvt.Attr.LocaleWhenSaved: ENU
' 6:< ::5:: Delta VM: Avail -20 -> 8383777 MB, Used +19 -> 380 MB, Peak +19 -> 380 MB; RAM: Avail -20 -> 11249 MB, Used +23 -> 489 MB, Peak +16 -> 489 MB
' 0.043025 7:<<<app infos and other global data
' 6:< File was saved in Autodesk Revit 2015 (Build: 20151007_1515(x64))
' 7:< ::5:: Delta VM: Avail -130 -> 8383647 MB, Used +129 -> 510 MB, Peak +129 -> 510 MB; RAM: Avail -128 -> 11121 MB, Used +126 -> 615 MB, Peak +126 -> 615 MB
' 0.006950 8:<<<ET::repairModificationDatesOutOfSequence
' 0.233120 7:<<ElemTable
' 0.081462 7:<<<ContentDocuments
' 0.011325 7:<<<History
' 0.004934 7:<<<increment table
' 6:< SLOG $b2f28696 2016-03-09 10:31:57.022 .Open:Local:LFV central=1597 local=1
' 0.000115 7:<<<fileExists?
' 0.012807 7:<<<WorksetTable
' 0.000008 7:<<<partitionStorageLock.open
' 6:< ::5:: Delta VM: Avail -4 -> 8383643 MB, Used +1 -> 511 MB, Peak +2 -> 512 MB; RAM: Avail +42 -> 11164 MB, Used +7 -> 623 MB, Peak +7 -> 623 MB
' 0.006703 7:<<<prepareLoadTargets
' 0.009308 8:<<<loadLatestVersionsEstimate
Message 8 of 23
' 8:< ::5:: Delta VM: Avail -18 -> 8383625 MB, Used +1 -> 512 MB; RAM: Avail -2 -> 11163 MB, Used +2 -> 625 MB, Peak +2 -> 626 MB
' 8:< Loaded elemStream#1596: uncompSize=65266, compSize=21631, count=41
' 8:< ::5:: Delta VM: Avail -18 -> 8383607 MB, Used +0 -> 513 MB, Peak +0 -> 513 MB; RAM: Avail -2 -> 11161 MB, Used +1 -> 627 MB, Peak +1 -> 627 MB
' 8:< Loaded elemStream#1595: uncompSize=837560, compSize=147351, count=499
' 8:< ::5:: Delta VM: Avail -26 -> 8383582 MB, Used +11 -> 524 MB, Peak +11 -> 524 MB; RAM: Avail -22 -> 11139 MB, Used +17 -> 644 MB, Peak +17 -> 645 MB
' 8:< Loaded elemStream#1594: uncompSize=15414787, compSize=3026189, count=17649
' 8:< Loaded elemStream#1593: uncompSize=803278, compSize=133995, count=533
' 8:< ::5:: Delta VM: Avail -12 -> 8383570 MB, Used +8 -> 532 MB, Peak +8 -> 532 MB; RAM: Avail -17 -> 11122 MB, Used +11 -> 655 MB, Peak +11 -> 657 MB
' 8:< Loaded elemStream#1592: uncompSize=11843585, compSize=2641903, count=5347
' 8:< ::5:: Delta VM: Avail -8 -> 8383562 MB, Used +4 -> 536 MB, Peak +4 -> 536 MB; RAM: Avail -14 -> 11108 MB, Used +4 -> 660 MB, Peak +4 -> 661 MB
' 8:< Loaded elemStream#1591: uncompSize=13406119, compSize=1837701, count=1701
' 8:< Loaded elemStream#1590: uncompSize=21139, compSize=6019, count=20
' 8:< Loaded elemStream#1588: uncompSize=32338, compSize=5873, count=25
' 8:< Loaded elemStream#1587: uncompSize=7635911, compSize=1217754, count=1685
' 8:< ::5:: Delta VM: Avail -2 -> 8383560 MB, Used 536 MB; RAM: Avail -12 -> 11097 MB, Used +3 -> 664 MB, Peak +2 -> 664 MB
' 8:< Loaded elemStream#1586: uncompSize=1864153, compSize=360872, count=172
' 8:< Loaded elemStream#1585: uncompSize=833018, compSize=152950, count=370
' 8:< Loaded elemStream#1583: uncompSize=247342, compSize=47081, count=240
' 8:< Loaded elemStream#1582: uncompSize=15965816, compSize=2680840, count=1166
' 8:< Loaded elemStream#1581: uncompSize=17943, compSize=4328, count=5
' 8:< ::5:: Delta VM: Avail -8 -> 8383552 MB, Used +8 -> 544 MB, Peak +8 -> 544 MB; RAM: Avail -19 -> 11078 MB, Used +15 -> 679 MB, Peak +15 -> 679 MB
' 8:< Loaded elemStream#1580: uncompSize=21454035, compSize=4490408, count=3758
' 8:< Loaded elemStream#1579: uncompSize=6526, compSize=2176, count=7
' 8:< Loaded elemStream#1578: uncompSize=142722, compSize=28248, count=113
' 8:< Loaded elemStream#1577: uncompSize=16578, compSize=2956, count=18
' 8:< Loaded elemStream#1576: uncompSize=68065, compSize=18068, count=20
' 8:< Loaded elemStream#1575: uncompSize=18528, compSize=3769, count=21
' 8:< Loaded elemStream#1574: uncompSize=24131, compSize=5223, count=24
' 8:< Loaded elemStream#1573: uncompSize=1289, compSize=803, count=2
' 8:< Loaded elemStream#1572: uncompSize=40277, compSize=6783, count=21
' 8:< Loaded elemStream#1571: uncompSize=13154, compSize=3330, count=17
' 8:< Loaded elemStream#1570: uncompSize=16187, compSize=4203, count=20
' 8:< Loaded elemStream#1569: uncompSize=21177, compSize=5081, count=21
' 8:< Loaded elemStream#1568: uncompSize=233014, compSize=33847, count=181
' 8:< Loaded elemStream#1567: uncompSize=114058, compSize=28757, count=82
' 8:< Loaded elemStream#1566: uncompSize=883, compSize=548, count=1
' 8:< Loaded elemStream#1563: uncompSize=114740, compSize=28248, count=101
' 8:< Loaded elemStream#1562: uncompSize=75948, compSize=14900, count=48
' 8:< Loaded elemStream#1561: uncompSize=75520, compSize=21631, count=48
' 8:< Loaded elemStream#1560: uncompSize=91817, compSize=25194, count=66
' 8:< Loaded elemStream#1559: uncompSize=12241, compSize=3070, count=8
' 8:< Loaded elemStream#1558: uncompSize=25949, compSize=7384, count=26
' 8:< Loaded elemStream#1557: uncompSize=6883022, compSize=1143187, count=1650
' 8:< ::5:: Delta VM: Avail 8383552 MB, Used 544 MB; RAM: Avail -16 -> 11062 MB, Used +2 -> 681 MB, Peak +2 -> 681 MB
' 8:< Loaded elemStream#1555: uncompSize=3700035, compSize=709784, count=298
' 8:< Loaded elemStream#1554: uncompSize=137798, compSize=25194, count=19
' 8:< Loaded elemStream#1553: uncompSize=88674, compSize=21631, count=9
' 8:< Loaded elemStream#1552: uncompSize=46444, compSize=13112, count=41
' 8:< Loaded elemStream#1551: uncompSize=20331, compSize=3403, count=30
' 8:< Loaded elemStream#1550: uncompSize=40903, compSize=9098, count=55
' 8:< Loaded elemStream#1549: uncompSize=61930, compSize=11170, count=58
' 8:< Loaded elemStream#1548: uncompSize=1583132, compSize=364435, count=38
' 8:< Loaded elemStream#1547: uncompSize=2746, compSize=1274, count=4
' 8:< Loaded elemStream#1546: uncompSize=1251538, compSize=247877, count=79
' 8:< Loaded elemStream#1545: uncompSize=164754, compSize=34865, count=47
' 8:< Loaded elemStream#1542: uncompSize=1012555, compSize=164657, count=649
' 8:< Loaded elemStream#1541: uncompSize=368753, compSize=61842, count=292
' 8:< Loaded elemStream#1540: uncompSize=41340, compSize=8725, count=36
' 8:< ::5:: Delta VM: Avail -97 -> 8383455 MB, Used +97 -> 642 MB, Peak +97 -> 642 MB; RAM: Avail -304 -> 10758 MB, Used +136 -> 818 MB, Peak +140 -> 822 MB
' 8:< Loaded elemStream#1538: uncompSize=260166588, compSize=42090018, count=96555
' 8:< Loaded elemStream#1537: uncompSize=117019, compSize=23667, count=81
' 8:< Loaded elemStream#1536: uncompSize=6319317, compSize=960206, count=3473
' 8:< Loaded elemStream#1534: uncompSize=119795, compSize=20104, count=117
' 8:< Loaded elemStream#1533: uncompSize=191351, compSize=20104, count=256
' 8:< Loaded elemStream#1532: uncompSize=637432, compSize=78861, count=299
' 8:< Loaded elemStream#1530: uncompSize=1858, compSize=803, count=2
' 8:< Loaded elemStream#1528: uncompSize=137493, compSize=15558, count=45
' 8:< Loaded elemStream#1527: uncompSize=340515, compSize=82964, count=76
' 8:< Loaded elemStream#1526: uncompSize=1051470, compSize=95180, count=1441
' 8:< Loaded elemStream#1524: uncompSize=528959, compSize=95689, count=149
' 8:< Loaded elemStream#1522: uncompSize=279016, compSize=43518, count=124
' 8:< Loaded elemStream#1520: uncompSize=55781, compSize=11008, count=36
' 8:< Loaded elemStream#1519: uncompSize=17810, compSize=4203, count=8
' 8:< Loaded elemStream#1518: uncompSize=276, compSize=381, count=1
' 8:< Loaded elemStream#1517: uncompSize=663699, compSize=146842, count=64
' 8:< Loaded elemStream#1516: uncompSize=3831, compSize=1274, count=2
' 8:< Loaded elemStream#1515: uncompSize=611703, compSize=77773, count=39
' 8:< ::5:: Delta VM: Avail -13 -> 8383443 MB, Used +12 -> 654 MB, Peak +12 -> 654 MB; RAM: Avail -45 -> 10714 MB, Used +33 -> 851 MB, Peak +28 -> 851 MB
' 8:< Loaded elemStream#1513: uncompSize=56762438, compSize=9005783, count=20175
' 8:< Loaded elemStream#1512: uncompSize=2186242, compSize=312773, count=454
' 8:< ::5:: Delta VM: Avail -17 -> 8383427 MB, Used +12 -> 666 MB, Peak +12 -> 666 MB; RAM: Avail -43 -> 10671 MB, Used +6 -> 858 MB, Peak +8 -> 860 MB
' 8:< Loaded elemStream#1511: uncompSize=33553685, compSize=5898919, count=32664
' 8:< Loaded elemStream#1510: uncompSize=1503994, compSize=190616, count=1317
' 8:< Loaded elemStream#1509: uncompSize=8303460, compSize=833468, count=1574
' 8:< Loaded elemStream#1508: uncompSize=23251, compSize=5272, count=29
' 8:< Loaded elemStream#1507: uncompSize=25213, compSize=5621, count=23
' 8:< Loaded elemStream#1506: uncompSize=9885, compSize=3046, count=13
' 8:< ::5:: Delta VM: Avail -4 -> 8383423 MB, Used +4 -> 670 MB, Peak +4 -> 670 MB; RAM: Avail -11 -> 10661 MB, Used +11 -> 870 MB, Peak +9 -> 870 MB
' 8:< Loaded elemStream#1503: uncompSize=15208611, compSize=2688984, count=1790
' 8:< Loaded elemStream#1500: uncompSize=12151, compSize=3102, count=9
' 8:< Loaded elemStream#1499: uncompSize=308600, compSize=13640, count=16
' 8:< Loaded elemStream#1498: uncompSize=5906027, compSize=943918, count=3976
' 8:< Loaded elemStream#1492: uncompSize=1690, compSize=681, count=2
' 8:< Loaded elemStream#1491: uncompSize=73556, compSize=13705, count=14
' 8:< Loaded elemStream#1490: uncompSize=843125, compSize=77009, count=300
' 8:< Loaded elemStream#1487: uncompSize=58745, compSize=9115, count=69
' 8:< Loaded elemStream#1483: uncompSize=164015, compSize=24176, count=19
' 8:< Loaded elemStream#1482: uncompSize=19314, compSize=5312, count=30
' 8:< Loaded elemStream#1481: uncompSize=117799, compSize=22649, count=2
' 8:< Loaded elemStream#1479: uncompSize=907703, compSize=121139, count=35
' 8:< Loaded elemStream#1477: uncompSize=50542, compSize=12113, count=25
' 8:< Loaded elemStream#1476: uncompSize=5528, compSize=1802, count=6
' 8:< Loaded elemStream#1475: uncompSize=188174, compSize=35374, count=186
' 8:< Loaded elemStream#1474: uncompSize=600372, compSize=120121, count=254
' 8:< Loaded elemStream#1472: uncompSize=39670, compSize=7839, count=33
' 8:< Loaded elemStream#1470: uncompSize=235033, compSize=43009, count=242
' 8:< ::5:: Delta VM: Avail 8383423 MB, Used 670 MB; RAM: Avail -11 -> 10651 MB, Used -3 -> 867 MB, Peak +4 -> 874 MB
' 8:< Loaded elemStream#1469: uncompSize=371263, compSize=29775, count=293
' 8:< Loaded elemStream#1468: uncompSize=130376, compSize=26721, count=48
' 8:< Loaded elemStream#1467: uncompSize=440, compSize=389, count=2
' 8:< Loaded elemStream#1466: uncompSize=24132, compSize=5081, count=21
' 8:< Loaded elemStream#1464: uncompSize=688, compSize=454, count=3
' 8:< Loaded elemStream#1463: uncompSize=46375, compSize=9651, count=8
' 8:< Loaded elemStream#1462: uncompSize=488, compSize=381, count=2
' 8:< Loaded elemStream#1461: uncompSize=957, compSize=714, count=1
' 8:< Loaded elemStream#1460: uncompSize=4938, compSize=1859, count=7
' 8:< Loaded elemStream#1459: uncompSize=135703, compSize=28248, count=168
' 8:< ::5:: Delta VM: Avail -7 -> 8383417 MB, Used +6 -> 676 MB, Peak +6 -> 676 MB; RAM: Avail -14 -> 10637 MB, Used +11 -> 878 MB, Peak +3 -> 878 MB
' 8:< Loaded elemStream#1458: uncompSize=19084024, compSize=3431344, count=12594
' 8:< Loaded elemStream#1457: uncompSize=17387, compSize=5198, count=16
' 8:< ::5:: Delta VM: Avail -20 -> 8383397 MB, Used +20 -> 696 MB, Peak +20 -> 696 MB; RAM: Avail -60 -> 10578 MB, Used +27 -> 906 MB, Peak +27 -> 906 MB
' 8:< Loaded elemStream#1456: uncompSize=52160412, compSize=8297017, count=17348
' 8:< Loaded elemStream#1455: uncompSize=396, compSize=381, count=1
' 8:< Loaded elemStream#1454: uncompSize=5282052, compSize=1010341, count=851
' 8:< Loaded elemStream#1452: uncompSize=30982, compSize=4830, count=37
' 8:< Loaded elemStream#1450: uncompSize=59602, compSize=10780, count=10
' 8:< Loaded elemStream#1449: uncompSize=122716, compSize=19086, count=49
' 8:< Loaded elemStream#1448: uncompSize=206536, compSize=40973, count=114
' 8:< Loaded elemStream#1445: uncompSize=62696, compSize=16289, count=55
' 8:< Loaded elemStream#1444: uncompSize=1568682, compSize=190616, count=665
' 8:< Loaded elemStream#1443: uncompSize=3578, compSize=1124, count=4
' 8:< Loaded elemStream#1441: uncompSize=341002, compSize=53189, count=245
' 8:< Loaded elemStream#1440: uncompSize=2245110, compSize=298521, count=883
' 8:< Loaded elemStream#1438: uncompSize=45388, compSize=6758, count=41
' 8:< Loaded elemStream#1437: uncompSize=907099, compSize=156513, count=663
' 8:< Loaded elemStream#1436: uncompSize=3366027, compSize=379196, count=2910
' 8:< Loaded elemStream#1434: uncompSize=6704, compSize=2136, count=7
' 8:< Loaded elemStream#1433: uncompSize=15985, compSize=7238, count=6
' 8:< Loaded elemStream#1432: uncompSize=20661, compSize=5580, count=26
' 8:< Loaded elemStream#1430: uncompSize=812, compSize=505, count=2
' 8:< ::5:: Delta VM: Avail 8383397 MB, Used 696 MB; RAM: Avail -12 -> 10567 MB, Used +7 -> 913 MB, Peak +7 -> 913 MB
' 8:< Loaded elemStream#1429: uncompSize=3166989, compSize=671609, count=585
' 8:< Loaded elemStream#1428: uncompSize=70068, compSize=8318, count=69
' 8:< Loaded elemStream#1427: uncompSize=6380595, compSize=1475811, count=120
' 8:< Loaded elemStream#1426: uncompSize=2186187, compSize=343057, count=762
' 8:< Loaded elemStream#1425: uncompSize=30846, compSize=6287, count=34
' 8:< ::5:: Delta VM: Avail -4 -> 8383393 MB, Used +4 -> 700 MB, Peak +4 -> 700 MB; RAM: Avail -22 -> 10545 MB, Used +7 -> 920 MB, Peak +7 -> 920 MB
' 8:< Loaded elemStream#1424: uncompSize=11277668, compSize=2411160, count=1145
' 8:< Loaded elemStream#1423: uncompSize=3240384, compSize=574902, count=644
' 8:< Loaded elemStream#1422: uncompSize=809028, compSize=147351, count=25
' 8:< Loaded elemStream#1421: uncompSize=160985, compSize=23667, count=105
' 8:< Loaded elemStream#1420: uncompSize=109394, compSize=24685, count=56
' 8:< Loaded elemStream#1419: uncompSize=267190, compSize=37410, count=175
' 8:< ::5:: Delta VM: Avail -4 -> 8383389 MB, Used +4 -> 704 MB, Peak +4 -> 704 MB; RAM: Avail -13 -> 10532 MB, Used +3 -> 924 MB, Peak +3 -> 924 MB
' 8:< Loaded elemStream#1417: uncompSize=24625278, compSize=4123313, count=8029
' 8:< Loaded elemStream#1416: uncompSize=6412971, compSize=1066584, count=2036
' 8:< Loaded elemStream#1415: uncompSize=466277, compSize=87545, count=433
' 8:< Loaded elemStream#1414: uncompSize=7531, compSize=2574, count=5
' 8:< Loaded elemStream#1413: uncompSize=6789, compSize=2266, count=8
' 8:< Loaded elemStream#1412: uncompSize=13093, compSize=3330, count=14
' 8:< Loaded elemStream#1411: uncompSize=191714, compSize=33338, count=14
' 8:< Loaded elemStream#1410: uncompSize=9296, compSize=2030, count=21
' 8:< Loaded elemStream#1409: uncompSize=57397, compSize=12543, count=68
' 8:< Loaded elemStream#1408: uncompSize=376948, compSize=67576, count=349
' 8:< Loaded elemStream#1407: uncompSize=115389, compSize=21631, count=179
' 8:< Loaded elemStream#1404: uncompSize=19165, compSize=4328, count=5
' 8:< Loaded elemStream#1403: uncompSize=46575, compSize=10033, count=49
' 8:< Loaded elemStream#1402: uncompSize=494665, compSize=79203, count=417
' 8:< Loaded elemStream#1401: uncompSize=327793, compSize=49626, count=276
' 8:< Loaded elemStream#1400: uncompSize=47789, compSize=14323, count=34
' 8:< Loaded elemStream#1399: uncompSize=8125, compSize=2282, count=7
' 8:< Loaded elemStream#1397: uncompSize=39238, compSize=12324, count=26
' 8:< Loaded elemStream#1396: uncompSize=176814, compSize=31811, count=124
' 8:< Loaded elemStream#1395: uncompSize=186756, compSize=39955, count=114
' 8:< ::5:: Delta VM: Avail -4 -> 8383385 MB, Used +4 -> 708 MB, Peak +4 -> 708 MB; RAM: Avail -25 -> 10508 MB, Used +14 -> 938 MB, Peak +14 -> 938 MB
' 8:< Loaded elemStream#1393: uncompSize=16415721, compSize=2395044, count=3920
' 8:< Loaded elemStream#1391: uncompSize=314330, compSize=48099, count=196
' 8:< Loaded elemStream#1390: uncompSize=92557, compSize=18577, count=41
' 8:< Loaded elemStream#1388: uncompSize=416411, compSize=73474, count=274
' 8:< Loaded elemStream#1387: uncompSize=96193, compSize=18068, count=84
' 8:< Loaded elemStream#1386: uncompSize=30915, compSize=6458, count=37
' 8:< Loaded elemStream#1385: uncompSize=3894, compSize=1713, count=5
' 8:< Loaded elemStream#1384: uncompSize=12042, compSize=3241, count=16
' 8:< Loaded elemStream#1383: uncompSize=989662, compSize=181963, count=188
' 8:< Loaded elemStream#1382: uncompSize=5667, compSize=2257, count=7
' 8:< Loaded elemStream#1381: uncompSize=803220, compSize=145659, count=14
' 8:< Loaded elemStream#1380: uncompSize=13726, compSize=3696, count=12
' 8:< Loaded elemStream#1379: uncompSize=11958, compSize=3509, count=16
' 8:< Loaded elemStream#1378: uncompSize=304237, compSize=45554, count=262
' 8:< Loaded elemStream#1376: uncompSize=13094, compSize=2631, count=17
' 8:< Loaded elemStream#1375: uncompSize=1617909, compSize=276003, count=234
' 8:< Loaded elemStream#1372: uncompSize=1069, compSize=755, count=1
' 8:< Loaded elemStream#1371: uncompSize=948432, compSize=151932, count=360
' 8:< Loaded elemStream#1370: uncompSize=181469, compSize=26212, count=235
' 8:< Loaded elemStream#1369: uncompSize=22987, compSize=5491, count=16
' 8:< Loaded elemStream#1368: uncompSize=419394, compSize=59297, count=243
' 8:< Loaded elemStream#1367: uncompSize=251065, compSize=51662, count=103
' 8:< Loaded elemStream#1366: uncompSize=1285399, compSize=177891, count=309
' 8:< Loaded elemStream#1364: uncompSize=1706995, compSize=275004, count=1025
' 8:< Loaded elemStream#1363: uncompSize=38829, compSize=3915, count=52
' 8:< Loaded elemStream#1362: uncompSize=2880, compSize=1356, count=3
' 8:< Loaded elemStream#1361: uncompSize=858254, compSize=112486, count=403
' 8:< Loaded elemStream#1360: uncompSize=2215, compSize=966, count=2
' 8:< Loaded elemStream#1358: uncompSize=73913, compSize=11048, count=72
' 8:< Loaded elemStream#1357: uncompSize=276374, compSize=54207, count=206
' 8:< Loaded elemStream#1356: uncompSize=115843, compSize=15265, count=129
' 8:< Loaded elemStream#1355: uncompSize=182230, compSize=31811, count=71
' 8:< Loaded elemStream#1354: uncompSize=20592, compSize=1924, count=33
' 8:< Loaded elemStream#1353: uncompSize=68330, compSize=10472, count=102
' 8:< Loaded elemStream#1352: uncompSize=39352, compSize=5304, count=51
' 8:< Loaded elemStream#1351: uncompSize=368632, compSize=46063, count=192
' 8:< Loaded elemStream#1350: uncompSize=113327, compSize=9358, count=190
' 8:< ::5:: Delta VM: Avail -4 -> 8383381 MB, Used +4 -> 712 MB, Peak +4 -> 712 MB; RAM: Avail -12 -> 10497 MB, Used -3 -> 936 MB, Peak +2 -> 941 MB
' 8:< Loaded elemStream#1349: uncompSize=1258778, compSize=174328, count=1139
' 8:< Loaded elemStream#1348: uncompSize=132045, compSize=15688, count=166
' 8:< Loaded elemStream#1346: uncompSize=4984, compSize=1526, count=8
' 8:< Loaded elemStream#1344: uncompSize=5093, compSize=1737, count=7
' 8:< Loaded elemStream#1342: uncompSize=411, compSize=462, count=1
' 8:< Loaded elemStream#1341: uncompSize=634586, compSize=62860, count=249
' 8:< Loaded elemStream#1340: uncompSize=36488, compSize=12641, count=27
' 8:< Loaded elemStream#1339: uncompSize=23329, compSize=5337, count=23
' 8:< Loaded elemStream#1338: uncompSize=32580, compSize=7587, count=40
' 8:< Loaded elemStream#1337: uncompSize=30317, compSize=7287, count=39
' 8:< Loaded elemStream#1336: uncompSize=124380, compSize=24176, count=10
' 8:< Loaded elemStream#1335: uncompSize=13518, compSize=3655, count=20
' 8:< Loaded elemStream#1333: uncompSize=86539, compSize=9513, count=97
' 8:< Loaded elemStream#1331: uncompSize=212396, compSize=38428, count=209
' 8:< Loaded elemStream#1330: uncompSize=12802, compSize=3915, count=14
' 8:< Loaded elemStream#1329: uncompSize=4463, compSize=1754, count=9
' 8:< Loaded elemStream#1328: uncompSize=198236, compSize=29775, count=187
' 8:< Loaded elemStream#1327: uncompSize=16945, compSize=3582, count=19
' 8:< Loaded elemStream#1326: uncompSize=157888, compSize=15566, count=205
' 8:< Loaded elemStream#1324: uncompSize=1018608, compSize=126229, count=459
' 8:< Loaded elemStream#1318: uncompSize=207260, compSize=30284, count=198
' 8:< Loaded elemStream#1317: uncompSize=50819, compSize=9813, count=3
' 8:< Loaded elemStream#1316: uncompSize=94143, compSize=10073, count=20
' 8:< Loaded elemStream#1314: uncompSize=111021, compSize=14282, count=7
' 8:< Loaded elemStream#1312: uncompSize=7395, compSize=2152, count=7
' 8:< ::5:: Delta VM: Avail -8 -> 8383374 MB, Used +7 -> 719 MB, Peak +7 -> 719 MB; RAM: Avail -33 -> 10464 MB, Used +18 -> 955 MB, Peak +14 -> 955 MB
' 8:< Loaded elemStream#1311: uncompSize=29161054, compSize=5364481, count=11198
' 8:< Loaded elemStream#1309: uncompSize=17364, compSize=2257, count=16
' 8:< Loaded elemStream#1308: uncompSize=147437, compSize=31811, count=9
' 8:< Loaded elemStream#1303: uncompSize=1360915, compSize=186035, count=1135
' 8:< Loaded elemStream#1302: uncompSize=120805, compSize=17050, count=118
' 8:< Loaded elemStream#1300: uncompSize=132620, compSize=29266, count=24
' 8:< Loaded elemStream#1299: uncompSize=324753, compSize=47590, count=288
' 8:< Loaded elemStream#1298: uncompSize=2051091, compSize=313791, count=1277
' 8:< Loaded elemStream#1297: uncompSize=218, compSize=348, count=1
' 8:< Loaded elemStream#1293: uncompSize=990, compSize=476, count=3
' 8:< ::5:: Delta VM: Avail -4 -> 8383370 MB, Used +4 -> 723 MB, Peak +4 -> 723 MB; RAM: Avail -14 -> 10450 MB, Used +8 -> 963 MB, Peak +8 -> 963 MB
' 8:< Loaded elemStream#1292: uncompSize=21004206, compSize=3075815, count=4695
' 8:< Loaded elemStream#1291: uncompSize=12718, compSize=2761, count=14
' 8:< Loaded elemStream#1290: uncompSize=1022, compSize=592, count=4
' 8:< Loaded elemStream#1289: uncompSize=841, compSize=625, count=3
' 8:< Loaded elemStream#1286: uncompSize=26302, compSize=6247, count=8
' 8:< Loaded elemStream#1285: uncompSize=435821, compSize=49626, count=288
' 8:< Loaded elemStream#1284: uncompSize=7870, compSize=2639, count=6
' 8:< Loaded elemStream#1283: uncompSize=22189, compSize=4956, count=19
' 8:< Loaded elemStream#1282: uncompSize=234441, compSize=31811, count=126
' 8:< Loaded elemStream#1280: uncompSize=103077, compSize=19086, count=25
' 8:< Loaded elemStream#1278: uncompSize=59330, compSize=11113, count=4
' 8:< ::5:: Delta VM: Avail -4 -> 8383366 MB, Used +4 -> 727 MB, Peak +4 -> 727 MB; RAM: Avail -17 -> 10434 MB, Used -1 -> 962 MB, Peak +4 -> 968 MB
' 8:< Loaded elemStream#1276: uncompSize=24154474, compSize=3517967, count=6944
' 8:< Loaded elemStream#1274: uncompSize=4265, compSize=1656, count=7
' 8:< Loaded elemStream#1273: uncompSize=154387, compSize=27230, count=88
' 8:< Loaded elemStream#1272: uncompSize=407567, compSize=70119, count=393
' 8:< Loaded elemStream#1271: uncompSize=9823, compSize=2786, count=17
' 8:< Loaded elemStream#1269: uncompSize=1056971, compSize=132594, count=645
' 8:< Loaded elemStream#1268: uncompSize=156015, compSize=28248, count=313
' 8:< Loaded elemStream#1265: uncompSize=834, compSize=625, count=1
' 8:< Loaded elemStream#1264: uncompSize=12687933, compSize=1909723, count=3861
' 8:< Loaded elemStream#1262: uncompSize=7900, compSize=2712, count=6
' 8:< Loaded elemStream#1261: uncompSize=880030, compSize=154477, count=94
' 8:< ::5:: Delta VM: Avail -2 -> 8383365 MB, Used 727 MB; RAM: Avail -17 -> 10418 MB, Used +5 -> 967 MB, Peak +2 -> 971 MB
' 8:< Loaded elemStream#1258: uncompSize=3150710, compSize=532418, count=491
' 8:< Loaded elemStream#1257: uncompSize=359602, compSize=44536, count=284
' 8:< Loaded elemStream#1256: uncompSize=32553, compSize=5775, count=6
' 8:< Loaded elemStream#1253: uncompSize=20862807, compSize=3314150, count=2354
' 8:< Loaded elemStream#1251: uncompSize=31984, compSize=4454, count=4
' 8:< Loaded elemStream#1250: uncompSize=733605, compSize=127247, count=392
' 8:< Loaded elemStream#1249: uncompSize=10477, compSize=2916, count=5
' 8:< Loaded elemStream#1248: uncompSize=89020, compSize=8993, count=12
' 8:< Loaded elemStream#1247: uncompSize=780, compSize=491, count=2
' 8:< Loaded elemStream#1246: uncompSize=606939, compSize=138379, count=255
' 8:< Loaded elemStream#1245: uncompSize=32114, compSize=8546, count=9
' 8:< Loaded elemStream#1244: uncompSize=37007, compSize=7075, count=4
' 8:< Loaded elemStream#1243: uncompSize=8760, compSize=1526, count=8
' 8:< Loaded elemStream#1242: uncompSize=36398, compSize=5629, count=5
' 8:< Loaded elemStream#1241: uncompSize=4346, compSize=1184, count=5
' 8:< Loaded elemStream#1240: uncompSize=4101947, compSize=553015, count=2661
' 8:< Loaded elemStream#1238: uncompSize=47151, compSize=10017, count=67
' 8:< Loaded elemStream#1237: uncompSize=1786, compSize=917, count=2
' 8:< Loaded elemStream#1236: uncompSize=7071, compSize=2144, count=2
' 8:< Loaded elemStream#1235: uncompSize=1066, compSize=608, count=2
' 8:< Loaded elemStream#1234: uncompSize=410727, compSize=58788, count=355
' 8:< ::5:: Delta VM: Avail -5 -> 8383361 MB, Used +4 -> 731 MB, Peak +4 -> 731 MB; RAM: Avail -10 -> 10408 MB, Used +10 -> 977 MB, Peak +8 -> 979 MB
' 8:< Loaded elemStream#1233: uncompSize=97157, compSize=14997, count=135
' 8:< Loaded elemStream#1232: uncompSize=347277, compSize=71622, count=130
' 8:< Loaded elemStream#1230: uncompSize=893042, compSize=159567, count=152
' 8:< Loaded elemStream#1229: uncompSize=319990, compSize=52680, count=74
' 8:< Loaded elemStream#1228: uncompSize=146716, compSize=22649, count=45
' 8:< Loaded elemStream#1227: uncompSize=69446, compSize=18068, count=65
' 8:< Loaded elemStream#1226: uncompSize=191438, compSize=40973, count=70
' 8:< Loaded elemStream#1225: uncompSize=7160445, compSize=1360780, count=478
' 8:< Loaded elemStream#1224: uncompSize=70934, compSize=12332, count=134
' 8:< Loaded elemStream#1222: uncompSize=3163, compSize=1542, count=5
' 8:< Loaded elemStream#1221: uncompSize=2313, compSize=1094, count=3
' 8:< ::5:: Delta VM: Avail -8 -> 8383353 MB, Used +8 -> 739 MB, Peak +8 -> 739 MB; RAM: Avail -49 -> 10360 MB, Used +14 -> 992 MB, Peak +15 -> 995 MB
' 8:< Loaded elemStream#1220: uncompSize=51477579, compSize=10256776, count=4362
' 8:< Loaded elemStream#1219: uncompSize=257382, compSize=38937, count=195
' 8:< Loaded elemStream#1218: uncompSize=1402, compSize=616, count=5
' 8:< Loaded elemStream#1217: uncompSize=129889, compSize=20104, count=152
' 8:< Loaded elemStream#1216: uncompSize=273197, compSize=40464, count=37
' 8:< Loaded elemStream#1215: uncompSize=309836, compSize=52171, count=32
' 8:< Loaded elemStream#1214: uncompSize=14652, compSize=3517, count=22
' 8:< Loaded elemStream#1213: uncompSize=113562, compSize=11991, count=101
' 8:< Loaded elemStream#1212: uncompSize=333671, compSize=41482, count=634
' 8:< Loaded elemStream#1209: uncompSize=723776, compSize=105360, count=29
' 8:< ::5:: Delta VM: Avail 8383353 MB, Used 739 MB; RAM: Avail -11 -> 10349 MB, Used +11 -> 1003 MB, Peak +8 -> 1003 MB
' 8:< Loaded elemStream#1208: uncompSize=20084160, compSize=2359414, count=16471
' 8:< Loaded elemStream#1205: uncompSize=468317, compSize=63369, count=460
' 8:< Loaded elemStream#1204: uncompSize=54057, compSize=4956, count=53
' 8:< Loaded elemStream#1202: uncompSize=14217, compSize=3135, count=13
' 8:< Loaded elemStream#1201: uncompSize=307689, compSize=48099, count=317
' 8:< Loaded elemStream#1200: uncompSize=376980, compSize=64387, count=167
' 8:< Loaded elemStream#1199: uncompSize=19561609, compSize=3046549, count=8592
' 8:< Loaded elemStream#1198: uncompSize=458708, compSize=50135, count=162
' 8:< Loaded elemStream#1197: uncompSize=2088, compSize=885, count=3
' 8:< Loaded elemStream#1195: uncompSize=359845, compSize=70696, count=17
' 8:< Loaded elemStream#1193: uncompSize=202989, compSize=37919, count=68
' 8:< Loaded elemStream#1192: uncompSize=156149, compSize=29775, count=51
' 8:< Loaded elemStream#1190: uncompSize=19957, compSize=5402, count=18
' 8:< Loaded elemStream#1188: uncompSize=8488, compSize=2786, count=6
' 8:< Loaded elemStream#1187: uncompSize=1810, compSize=1064, count=4
' 8:< Loaded elemStream#1185: uncompSize=166639, compSize=29266, count=47
' 8:< Loaded elemStream#1184: uncompSize=224801, compSize=33847, count=128
' 8:< Loaded elemStream#1183: uncompSize=74249, compSize=11845, count=9
' 8:< Loaded elemStream#1182: uncompSize=1032900, compSize=202860, count=1336
' 8:< Loaded elemStream#1181: uncompSize=145389, compSize=32320, count=27
' 8:< ::5:: Delta VM: Avail -8 -> 8383345 MB, Used +8 -> 747 MB, Peak +8 -> 747 MB; RAM: Avail -8 -> 10342 MB, Used +8 -> 1012 MB, Peak +10 -> 1014 MB
' 8:< Loaded elemStream#1179: uncompSize=16849282, compSize=3335399, count=2201
' 8:< Loaded elemStream#1177: uncompSize=17281, compSize=4029, count=14
' 8:< Loaded elemStream#1176: uncompSize=12744189, compSize=2265252, count=3570
' 8:< Loaded elemStream#1172: uncompSize=183484, compSize=20104, count=26
' 8:< Loaded elemStream#1169: uncompSize=5037, compSize=1599, count=1
' 8:< Loaded elemStream#1166: uncompSize=21697, compSize=5320, count=20
' 8:< Loaded elemStream#1165: uncompSize=251174, compSize=38937, count=66
' 8:< Loaded elemStream#1164: uncompSize=7476, compSize=1632, count=27
' 8:< Loaded elemStream#1163: uncompSize=353874, compSize=61333, count=77
' 8:< Loaded elemStream#1159: uncompSize=6815, compSize=2111, count=6
' 8:< Loaded elemStream#1158: uncompSize=15559, compSize=3866, count=11
' 8:< Loaded elemStream#1157: uncompSize=61456, compSize=14331, count=6
' 8:< Loaded elemStream#1156: uncompSize=667731, compSize=86018, count=210
' 8:< Loaded elemStream#1155: uncompSize=234818, compSize=33847, count=159
' 8:< Loaded elemStream#1154: uncompSize=547, compSize=505, count=2
' 8:< Loaded elemStream#1152: uncompSize=30663, compSize=5718, count=28
' 8:< Loaded elemStream#1151: uncompSize=8005, compSize=2347, count=1
' 8:< Loaded elemStream#1150: uncompSize=41297, compSize=9082, count=13
' 8:< Loaded elemStream#1149: uncompSize=55497, compSize=13657, count=12
' 8:< Loaded elemStream#1148: uncompSize=11214, compSize=3590, count=2
' 8:< Loaded elemStream#1147: uncompSize=488, compSize=381, count=2
' 8:< Loaded elemStream#1145: uncompSize=1844307, compSize=352728, count=291
' 8:< Loaded elemStream#1144: uncompSize=8130, compSize=2420, count=9
' 8:< Loaded elemStream#1143: uncompSize=6339, compSize=1551, count=7
' 8:< ::5:: Delta VM: Avail -4 -> 8383341 MB, Used +4 -> 752 MB, Peak +4 -> 752 MB; RAM: Avail -1 -> 10341 MB, Used +11 -> 1023 MB, Peak +10 -> 1025 MB
' 8:< Loaded elemStream#1142: uncompSize=10241394, compSize=1999051, count=943
' 8:< Loaded elemStream#1141: uncompSize=5613966, compSize=1123845, count=406
' 8:< Loaded elemStream#1140: uncompSize=1605346, compSize=320917, count=82
' 8:< Loaded elemStream#1139: uncompSize=9253616, compSize=1733359, count=801
' 8:< Loaded elemStream#1138: uncompSize=143149, compSize=32320, count=10
' 8:< Loaded elemStream#1136: uncompSize=642782, compSize=125211, count=12
' 8:< Loaded elemStream#1135: uncompSize=382, compSize=365, count=1
' 8:< Loaded elemStream#1131: uncompSize=800230, compSize=168220, count=33
' 8:< Loaded elemStream#1129: uncompSize=370135, compSize=79698, count=9
' 8:< Loaded elemStream#1127: uncompSize=5476, compSize=1624, count=5
' 8:< Loaded elemStream#1126: uncompSize=1071233, compSize=227517, count=26
' 8:< Loaded elemStream#1125: uncompSize=1462, compSize=803, count=5
' 8:< Loaded elemStream#1122: uncompSize=2299954, compSize=314300, count=1606
' 8:< Loaded elemStream#1121: uncompSize=13352, compSize=3111, count=17
' 8:< Loaded elemStream#1119: uncompSize=821, compSize=616, count=1
' 8:< Loaded elemStream#1118: uncompSize=29525, compSize=6442, count=35
' 8:< Loaded elemStream#1117: uncompSize=8363, compSize=2566, count=12
' 8:< Loaded elemStream#1116: uncompSize=74296, compSize=10236, count=73
' 8:< Loaded elemStream#1115: uncompSize=2542, compSize=1124, count=6
' 8:< Loaded elemStream#1111: uncompSize=863, compSize=706, count=1
' 8:< Loaded elemStream#1109: uncompSize=4327, compSize=1551, count=6
' 8:< ::5:: Delta VM: Avail -4 -> 8383337 MB, Used +4 -> 756 MB, Peak +4 -> 756 MB; RAM: Avail -22 -> 10320 MB, Used +9 -> 1033 MB, Peak +10 -> 1035 MB
' 8:< Loaded elemStream#1108: uncompSize=27978235, compSize=5198577, count=3231
' 8:< Loaded elemStream#1107: uncompSize=13295, compSize=3232, count=11
' 8:< Loaded elemStream#1105: uncompSize=268790, compSize=47081, count=162
' 8:< Loaded elemStream#1104: uncompSize=1858, compSize=1004, count=2
' 8:< Loaded elemStream#1103: uncompSize=28576, compSize=5081, count=29
' 8:< Loaded elemStream#1101: uncompSize=20404, compSize=3151, count=18
' 8:< ::5:: Delta VM: Avail -4 -> 8383333 MB, Used +4 -> 760 MB, Peak +4 -> 760 MB; RAM: Avail -18 -> 10302 MB, Used +12 -> 1046 MB, Peak +10 -> 1046 MB
' 8:< Loaded elemStream#1100: uncompSize=17231792, compSize=3412511, count=10224
' 8:< ::5:: Delta VM: Avail -4 -> 8383329 MB, Used +4 -> 764 MB, Peak +4 -> 764 MB; RAM: Avail -19 -> 10284 MB, Used +4 -> 1050 MB, Peak +4 -> 1050 MB
' 8:< Loaded elemStream#1099: uncompSize=17003180, compSize=3376728, count=10448
' 8:< Loaded elemStream#1094: uncompSize=535392, compSize=97216, count=284
' 8:< ::5:: Delta VM: Avail -5 -> 8383325 MB, Used +4 -> 768 MB, Peak +4 -> 768 MB; RAM: Avail -21 -> 10263 MB, Used +8 -> 1059 MB, Peak +8 -> 1059 MB
' 8:< Loaded elemStream#1093: uncompSize=17736719, compSize=3500312, count=10435
' 8:< Loaded elemStream#1091: uncompSize=350201, compSize=36392, count=530
' 8:< Loaded elemStream#1090: uncompSize=547, compSize=505, count=2
' 8:< Loaded elemStream#1089: uncompSize=4908, compSize=1421, count=5
' 8:< Loaded elemStream#1088: uncompSize=8268, compSize=2916, count=13
' 8:< Loaded elemStream#1087: uncompSize=4692, compSize=1461, count=13
' 8:< Loaded elemStream#1086: uncompSize=26685, compSize=6230, count=16
' 8:< Loaded elemStream#1084: uncompSize=142410, compSize=20613, count=11
' 8:< Loaded elemStream#1081: uncompSize=8885, compSize=2712, count=9
' 8:< Loaded elemStream#1076: uncompSize=396, compSize=405, count=1
' 8:< Loaded elemStream#1075: uncompSize=3109, compSize=925, count=7
' 8:< Loaded elemStream#1074: uncompSize=791281, compSize=121648, count=719
' 8:< Loaded elemStream#1072: uncompSize=1999, compSize=852, count=4
' 8:< Loaded elemStream#1069: uncompSize=14075936, compSize=2278086, count=2242
' 8:< Loaded elemStream#1068: uncompSize=141884, compSize=25703, count=78
' 8:< Loaded elemStream#1065: uncompSize=17063, compSize=3013, count=18
' 8:< Loaded elemStream#1063: uncompSize=772293, compSize=152441, count=581
' 8:< Loaded elemStream#1061: uncompSize=14323, compSize=3809, count=10
' 8:< Loaded elemStream#1059: uncompSize=147631, compSize=32829, count=115
' 8:< Loaded elemStream#1058: uncompSize=11998, compSize=2875, count=12
' 8:< Loaded elemStream#1057: uncompSize=72877, compSize=8067, count=8
' 8:< Loaded elemStream#1056: uncompSize=21341, compSize=4328, count=13
' 8:< Loaded elemStream#1055: uncompSize=29269, compSize=6572, count=10
' 8:< Loaded elemStream#1054: uncompSize=23996, compSize=4830, count=22
' 8:< Loaded elemStream#1053: uncompSize=153633, compSize=29775, count=128
' 8:< Loaded elemStream#1051: uncompSize=174056, compSize=35883, count=41
' 8:< Loaded elemStream#1050: uncompSize=1419533, compSize=219373, count=1487
' 8:< Loaded elemStream#1049: uncompSize=5247, compSize=1924, count=8
' 8:< Loaded elemStream#1048: uncompSize=2093926, compSize=270332, count=1241
' 8:< ::5:: Delta VM: Avail -4 -> 8383321 MB, Used +4 -> 772 MB, Peak +4 -> 772 MB; RAM: Avail -11 -> 10253 MB, Used +8 -> 1067 MB, Peak +8 -> 1067 MB
' 8:< Loaded elemStream#1044: uncompSize=1055061, compSize=104851, count=547
' 8:< Loaded elemStream#1043: uncompSize=4131539, compSize=816671, count=3632
' 8:< Loaded elemStream#1042: uncompSize=3778, compSize=1154, count=3
' 8:< ::5:: Delta VM: Avail -8 -> 8383313 MB, Used +8 -> 780 MB, Peak +8 -> 780 MB; RAM: Avail -18 -> 10235 MB, Used +6 -> 1074 MB, Peak +6 -> 1074 MB
' 8:< Loaded elemStream#1041: uncompSize=17348232, compSize=2485134, count=26697
' 8:< Loaded elemStream#1040: uncompSize=7490, compSize=2071, count=16
' 8:< Loaded elemStream#1039: uncompSize=35199, compSize=6060, count=41
' 8:< Loaded elemStream#1038: uncompSize=8848948, compSize=1828396, count=2671
' 8:< Loaded elemStream#1037: uncompSize=8338, compSize=2485, count=7
' 8:< Loaded elemStream#1036: uncompSize=605, compSize=584, count=1
' 8:< Loaded elemStream#1034: uncompSize=1859374, compSize=413043, count=1041
' 8:< Loaded elemStream#1033: uncompSize=10772, compSize=3119, count=16
' 8:< Loaded elemStream#1032: uncompSize=44824, compSize=6767, count=35
' 8:< Loaded elemStream#1031: uncompSize=39644, compSize=6848, count=14
' 8:< Loaded elemStream#1028: uncompSize=2137034, compSize=281215, count=1985
' 8:< Loaded elemStream#1027: uncompSize=25391, compSize=5759, count=26
' 8:< Loaded elemStream#1026: uncompSize=4108, compSize=1461, count=6
' 8:< Loaded elemStream#1025: uncompSize=4106, compSize=1713, count=4
' 8:< Loaded elemStream#1022: uncompSize=5997, compSize=1347, count=7
' 8:< Loaded elemStream#1021: uncompSize=11210, compSize=3046, count=3
' 8:< ::5:: Delta VM: Avail -4 -> 8383309 MB, Used +4 -> 784 MB, Peak +4 -> 784 MB; RAM: Avail -14 -> 10222 MB, Used +7 -> 1081 MB, Peak +10 -> 1084 MB
' 8:< Loaded elemStream#1020: uncompSize=10936834, compSize=1710963, count=2023
' 8:< Loaded elemStream#1017: uncompSize=6711, compSize=2087, count=1
' 8:< Loaded elemStream#1015: uncompSize=58848, compSize=15477, count=16
' 8:< Loaded elemStream#1013: uncompSize=121415, compSize=22140, count=46
' 8:< Loaded elemStream#1012: uncompSize=249845, compSize=57261, count=70
' 8:< Loaded elemStream#1010: uncompSize=25112, compSize=5848, count=28
' 8:< Loaded elemStream#1009: uncompSize=1964612, compSize=470309, count=202
' 8:< Loaded elemStream#1005: uncompSize=1279, compSize=649, count=4
' 8:< Loaded elemStream#1004: uncompSize=555, compSize=548, count=1
' 8:< Loaded elemStream#1003: uncompSize=763686, compSize=135129, count=7
' 8:< Loaded elemStream#1001: uncompSize=275353, compSize=27739, count=183
' 8:< Loaded elemStream#999: uncompSize=38839, compSize=7425, count=5
' 8:< Loaded elemStream#997: uncompSize=569647, compSize=77212, count=76
' 8:< Loaded elemStream#996: uncompSize=6957289, compSize=1252110, count=1644
' 8:< Loaded elemStream#994: uncompSize=47549, compSize=4956, count=6
' 8:< ::5:: Delta VM: Avail 8383309 MB, Used 784 MB; RAM: Avail -14 -> 10208 MB, Used +11 -> 1093 MB, Peak +9 -> 1093 MB
' 8:< Loaded elemStream#991: uncompSize=17188455, compSize=2893343, count=3763
' 8:< Loaded elemStream#990: uncompSize=188592, compSize=31811, count=25
' 8:< Loaded elemStream#988: uncompSize=67234, compSize=14664, count=1
' 8:< Loaded elemStream#986: uncompSize=31694, compSize=8002, count=7
' 8:< Loaded elemStream#984: uncompSize=10350, compSize=3102, count=11
' 8:< Loaded elemStream#983: uncompSize=165949, compSize=17050, count=190
' 8:< Loaded elemStream#982: uncompSize=2814212, compSize=625037, count=1224
' 8:< Loaded elemStream#981: uncompSize=123682, compSize=18577, count=131
' 8:< Loaded elemStream#977: uncompSize=1466, compSize=811, count=2
' 8:< Loaded elemStream#973: uncompSize=3763173, compSize=650381, count=3150
' 8:< Loaded elemStream#972: uncompSize=2694, compSize=722, count=6
' 8:< Loaded elemStream#971: uncompSize=8173, compSize=2176, count=15
' 8:< Loaded elemStream#969: uncompSize=129829, compSize=17050, count=37
' 8:< Loaded elemStream#968: uncompSize=276, compSize=405, count=1
' 8:< Loaded elemStream#966: uncompSize=1120, compSize=665, count=3
' 8:< Loaded elemStream#965: uncompSize=6786, compSize=1583, count=8
' 8:< Loaded elemStream#962: uncompSize=857708, compSize=126738, count=694
' 8:< Loaded elemStream#960: uncompSize=25561, compSize=4579, count=10
' 8:< Loaded elemStream#959: uncompSize=679, compSize=568, count=2
' 8:< Loaded elemStream#958: uncompSize=2225393, compSize=197587, count=2581
' 8:< Loaded elemStream#957: uncompSize=37643, compSize=7059, count=8
' 8:< Loaded elemStream#956: uncompSize=73454, compSize=6295, count=90
' 8:< Loaded elemStream#955: uncompSize=134204, compSize=27739, count=2
' 8:< Loaded elemStream#950: uncompSize=461, compSize=476, count=1
' 8:< Loaded elemStream#949: uncompSize=757540, compSize=132196, count=67
' 8:< Loaded elemStream#948: uncompSize=3586, compSize=1331, count=4
' 8:< Loaded elemStream#947: uncompSize=8285, compSize=2006, count=9
' 8:< Loaded elemStream#946: uncompSize=305980, compSize=29775, count=53
' 8:< ::5:: Delta VM: Avail -4 -> 8383305 MB, Used +4 -> 788 MB, Peak +4 -> 788 MB; RAM: Avail -12 -> 10196 MB, Used +8 -> 1102 MB, Peak +8 -> 1102 MB
' 8:< Loaded elemStream#945: uncompSize=1898111, compSize=221918, count=835
' 8:< Loaded elemStream#941: uncompSize=2124, compSize=941, count=4
' 8:< Loaded elemStream#940: uncompSize=644503, compSize=105360, count=157
' 8:< Loaded elemStream#939: uncompSize=585819, compSize=81274, count=200
' 8:< Loaded elemStream#938: uncompSize=329695, compSize=59297, count=461
' 8:< Loaded elemStream#936: uncompSize=666368, compSize=103833, count=150
' 8:< Loaded elemStream#934: uncompSize=722, compSize=592, count=1
' 8:< Loaded elemStream#931: uncompSize=122946, compSize=13315, count=20
' 8:< Loaded elemStream#928: uncompSize=3247, compSize=1274, count=7
' 8:< Loaded elemStream#927: uncompSize=468673, compSize=53698, count=200
' 8:< Loaded elemStream#926: uncompSize=9986, compSize=2396, count=34
' 8:< Loaded elemStream#924: uncompSize=2394, compSize=1094, count=6
' 8:< Loaded elemStream#923: uncompSize=780, compSize=430, count=2
' 8:< Loaded elemStream#922: uncompSize=220, compSize=340, count=1
' 8:< Loaded elemStream#921: uncompSize=7332, compSize=1640, count=27
' 8:< Loaded elemStream#920: uncompSize=1534, compSize=771, count=2
' 8:< Loaded elemStream#917: uncompSize=29428, compSize=6823, count=32
' 8:< Loaded elemStream#915: uncompSize=3860521, compSize=344075, count=1523
' 8:< Loaded elemStream#913: uncompSize=352, compSize=438, count=1
' 8:< Loaded elemStream#912: uncompSize=2806594, compSize=270437, count=349
' 8:< Loaded elemStream#911: uncompSize=1461438, compSize=310228, count=261
' 8:< Loaded elemStream#910: uncompSize=34229, compSize=6295, count=4
' 8:< Loaded elemStream#909: uncompSize=1381900, compSize=160585, count=1207
' 8:< Loaded elemStream#905: uncompSize=1658634, compSize=336447, count=1679
' 8:< Loaded elemStream#903: uncompSize=46567, compSize=7880, count=47
' 8:< Loaded elemStream#902: uncompSize=155830, compSize=23158, count=29
' 8:< Loaded elemStream#901: uncompSize=304295, compSize=57261, count=382
' 8:< Loaded elemStream#900: uncompSize=24212, compSize=4705, count=14
' 8:< Loaded elemStream#898: uncompSize=4146, compSize=1274, count=4
' 8:< Loaded elemStream#896: uncompSize=900107, compSize=150914, count=157
' 8:< ::5:: Delta VM: Avail -8 -> 8383297 MB, Used +8 -> 796 MB, Peak +8 -> 796 MB; RAM: Avail -12 -> 10185 MB, Used 1102 MB, Peak +0 -> 1103 MB
' 8:< Loaded elemStream#895: uncompSize=2749220, compSize=452236, count=2383
' 8:< Loaded elemStream#894: uncompSize=1089282, compSize=250931, count=70
' 8:< Loaded elemStream#893: uncompSize=5072, compSize=1412, count=6
' 8:< Loaded elemStream#891: uncompSize=16478, compSize=3387, count=19
' 8:< Loaded elemStream#890: uncompSize=249757, compSize=37410, count=50
' 8:< Loaded elemStream#889: uncompSize=2660, compSize=1184, count=2
' 8:< Loaded elemStream#887: uncompSize=2152342, compSize=353237, count=340
' 8:< ::5:: Delta VM: Avail -9 -> 8383289 MB, Used +8 -> 804 MB, Peak +8 -> 804 MB; RAM: Avail -23 -> 10162 MB, Used +17 -> 1119 MB, Peak +16 -> 1119 MB
' 8:< Loaded elemStream#885: uncompSize=20710057, compSize=4718575, count=17396
' 8:< An ArchiveException 105 is raised at line 2526 of Archive\AArcObj.cpp: reach the end of file.
' 8:< Failed to load elemStream#878
' 2.514051========= 8:<<<loadLatestVersion
' 2.523434======== 7:<<loadSelectedEpochs
' 6:< ::5:: Delta VM: Avail -10 -> 8383279 MB, Used +9 -> 814 MB, Peak +13 -> 818 MB; RAM: Avail -22 -> 10140 MB, Used +11 -> 1131 MB, Peak +15 -> 1135 MB
' 6:< Before : Destroy Display Manager
' 6:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 6:< RAM Statistics: 10140 / 16325 1131=InUse 1135=Peak
' 6:< VM Statistics: 8383279 / 8388607 814=InUse 818=Peak
' 6:< After : Destroy Display Manager
' 5:< ::5:: Delta VM: Avail +147 -> 8383427 MB, Used -144 -> 670 MB; RAM: Avail +138 -> 10279 MB, Used -141 -> 990 MB
' 3.824134======= 6:<<TrustedUtility::readStreams/ALL_GAPS 0.907201/TurnOff_GAPs 5%
' 3.848153===== 4:<<loadSerialize
' 3.848755==== 3:<<LoadFromStorage
' 4:< SLOG $b2f28696 2016-03-09 10:32:00.457 .Open:Local:LockUsers RW unlocked
' 0.000135 5:<<<fileExists?
' 0.007166 4:<<relinquishPermissionsLocks
' 3:< ::5:: Delta VM: Avail +988 -> 8384415 MB, Used -2 -> 668 MB; RAM: Avail +9 -> 10289 MB, Used -208 -> 782 MB
' 3:< DummyStorage destroying DataStorageInterface 0x00000000497DC760
' 0.018160 3:<<relinquishAllLocks
' 3:< Connecting session [$37e3b39e] to Worksharing Log [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\Journals\journal.0115.txt]
' 0.000010 4:<<<WorksharingLog::getSlog []
' 3:< TaskDialog "Data in file 2015072 100 Hooper - Cloud.rvt is corrupt and needs to be manually recovered.
'Please contact Autodesk Support.
'CommonButtons : Close
'DefaultButton : Close
' 3:< ::5:: Delta VM: Avail -1 -> 8384414 MB, Used 668 MB; RAM: Avail +54 -> 10344 MB, Used 782 MB
'H 09-Mar-2016 10:32:02.107; 3:<
Jrn.Data "TaskDialogResult" _
, "Data in file 2015072 100 Hooper - Cloud.rvt is corrupt and needs to be manually recovered." & vbCrLf & "Please contact Autodesk Support." & vbCrLf & "", _
"Close", "IDCLOSE"
'C 09-Mar-2016 10:32:02.108; 3:< Load exception "CArchiveException", code=105: Data in file an unnamed file is corrupt and needs to be manually recovered.
' 1.639103!!!!! 4:!!!BIG_GAP exceptionsInOnOpenDocument reportSaveLoadException bSaving=no [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt]
' 1.639331 3:<<exceptionsInOnOpenDocument reportSaveLoadException bSaving=no [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt]
' 0.000006 3:<<<relinquishAllLocks
' 2:< SLOG $b2f28696 2016-03-09 10:32:02.111 <Open:Local
' 0.000111 3:<<<fileExists?
' 0.000068 3:<<<fileExists?
' 2:< SLOG $b2f28696 2016-03-09 10:32:02.111 <Session
' 0.000067 3:<<<fileExists?
' 5.512213 2:<<FormOrAbandon::openFromModelPath [C:\Users\f_a\AppData\Local\Autodesk\Revit\Autodesk Revit 2015\CollaborationCache\ZE3VJ2QTQFPK\fb36b3dc-9dbd-4c87-9311-84027589a2a5\4c8c3250-f7c1-4e79-8845-d4a66aac5307.rvt]
' 1:< DBG_INFO: openFromModelPath did not complete.: line 467 of Project\FormOrAbandon.cpp.
' 1:< DBG_INFO: formDocumentStorage did not complete: line 142 of Project\FormOrAbandon.cpp.
' 1:< compact data space: 776054 blocks, occupying total of 824289172 bytes
' 1:< freed 524696 blocks
' 1:< ::5:: Delta VM: Avail +39 -> 8384453 MB, Used -3 -> 665 MB; RAM: Avail +787 -> 11131 MB, Used -16 -> 767 MB
' 1:< RAM Statistics: 11132 / 16325 767=InUse 1135=Peak
' 1:< VM Statistics: 8384453 / 8388607 665=InUse 818=Peak
' 5.622049-- 1:<<[Cloud]standardOpenDocumentFile
' 0:< ::5:: Delta VM: Avail +20 -> 8384474 MB, Used +0 -> 666 MB; RAM: Avail +260 -> 11392 MB, Used +0 -> 768 MB
'E 09-Mar-2016 10:32:16.537; 0:<
Jrn.Command "SystemMenu" , "Quit the application; prompts to save projects , ID_APP_EXIT"
' 0:< ::6:: Delta VM: Avail +40 -> 8384514 MB, Used -10 -> 656 MB; RAM: Avail +10 -> 11402 MB, Used -10 -> 758 MB
' 0:< ->desktop ExitManagedInstance
' 0:< ::6:: Delta VM: Avail -18 -> 8384496 MB, Used +1 -> 658 MB; RAM: Avail -1 -> 11401 MB, Used +3 -> 762 MB
' 0:< <-desktop ExitManagedInstance
' 0:< ->desktop ExitNativeInstance
' 0:< API unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9).
' 0:< API unregistering ApplicationClosing event by application Ribbon (603a4c35-f8a1-4b4e-8ae3-d55ee114027d).
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14).
' 0:< API unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< API unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< API unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f).
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::6:: Delta VM: Avail +40 -> 8384537 MB, Used -38 -> 620 MB; RAM: Avail +1 -> 11403 MB, Used -3 -> 759 MB
'C 09-Mar-2016 10:32:16.978; 0:< License cleanup complete: 0, 0
' 0:< Journal Exit
' 0:< Log Summary
' 0:< .Count
' 0:< ...CloseHiddenWindowsInAllDocuments = 4
' 0:< ...DBG_SOMETHING = 3
' 0:< ...getADocuments_Arr = 941
' 0:< ...onUpdateWindowCloseHidden = 4
' 0:< ...Peeks = 78
' 0:< ...PendingMessages = 225
' 0:< Total session time spent reclaiming memory: 0.000000 seconds. Averaged 0.000000 seconds/call for 0 calls.
' 0:< BackgroundLoader exec= 1 (parallel= 1)
' 0:< ConsumeMultiSegmentFile exec= 10796 (parallel= 10796) self= 12.101942 sec (avg= 0.001)
' 0:< FormOrAbandon exec= 3 (parallel= 0) self= 5.616742 sec (avg= 1.872)
' 0:< PipeliningTask exec= 757 (parallel= 757)
' 0:< ProduceArchive exec= 11553 (parallel= 0) self= 0.653556 sec (avg= 0.000)
' 0:< TaskFileExists exec= 331 (parallel= 324)
' 0:< TaskProgressIndicator exec= 1 (parallel= 1)
' 0:< TaskWaitCursor exec= 1 (parallel= 1)
' 0:< ::6:: Delta VM: Avail +46 -> 8384583 MB, Used -1 -> 619 MB; RAM: Avail +24 -> 11428 MB, Used -8 -> 751 MB
' 0:< <-desktop ExitNativeInstance
'C 09-Mar-2016 10:32:17.518; 0:< finished recording journal file
Message 9 of 23
lars-ake.johansson
Hi Francesca,
For some reason one of the element streams (files) that are downloaded becomes corrupt.
Question: When you cleaned out the Collaboration-cache files on your syste, did you clean the PAC-cache as well (Personal Accelerator) - step 5 in the kb-article
5. Delete the model folder in the PacCache (delete the entire <Model GUID> folder):
C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\PacCache\<Model GUID>
From the journal it looks like you might not have .... I would expect to see a lot more of "PAC cache miss".....
BTW: This is problem is probably on your local system, the central model is most likely ok.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
Message 10 of 23
Thank you! This was able to open up my model. Unfortunately, I cannot click or even hover on certain elements like title blocks and viewports so my model does not seem fully restored. Again, nobody else is having this problem. Any suggestions? Do I need to begin another forum topic for this issue?
Message 11 of 23
i would double-check disk-space of where your current cache is on your local machine. i would also check network connectivity (NIC cards, switches, firewall(s) etc. from your machine, out to the internet. make sure both are functioning properly.
we've had the same issues both on the internal LAN and via a360, both culprits leading back to disk-space (local cache) and/or network connectivity issues. if the model gets interupted in anyway, when opening, saving, write-backs for whatever reason, it's at risk of failing. Also make sure you are All using the same Revit version, and then the same build numbers. Different revit build flavors Will lead to data corruption.
Once you are satisfied with your infrastrucutre then, i would focus on rebuilding your portion of the model. it seems the one you're attempting to resuscitate has passed and not worth the effort? bringing that model back to life may only result in the same problem.
good luck and hope that helps!
Message 12 of 23
hmunsell
Lars,
slightly off topic, but can you enlighten me as to what the ElemStream# is in the journal file?
it lists a uncomSize and compSize and a Count.  but what is the ElemDtream# referring to?
Howard Munsell
Message 13 of 23
sasha.crotty
An element stream is the way a Revit file is organized. Each stream contains the data for changed elements. For cloud workshared models, the element streams are broken out into separate data stores rather than being saved in a file.
Sasha Crotty
Director, AEC Design Data
Message 14 of 23
amitcivil876
I am facing same issue file is not opening and discussed with the support team, they said it cannot resolve.
Message 15 of 23
ccastelein
love to see how resolution of these problems are posted.
Message 16 of 23
RSomppi
This thread strays off topic so it's hard to understand your statement. If you are referring to the original question, Message 9 of 15 is the most likely solution.
Message 17 of 23
ccastelein
yeah, i have similar journal file verbiage, my system has been completely wiped all new installs over 500gb free..
was hoping for something other solution.
Message 18 of 23
RSomppi
Was this just uninstall and reinstall Revits?
Did you delete your collaboration cache and pac cache folders?
Message 19 of 23
ccastelein
Not following... wiped hard drive clean, installed windows, then installed Revit 2023, Sketchup 2023, and Enscape 4.0.5
and corruption.....curiously it seems only in the after noon..... (wipe was last tuesday)
IT had removed the four of us from a domain in which the servers were on prem. for all of us (2 groups - 2 offices), and re-configured us to a domain in which for 2 of us the server is miles away and the server on prem. for the other 2.
I am the only one that seems to have problems... i have a desktop pc only 4 years old with nvidia rtx 4000 card. ALL drivers have been updated. and programs patched. the other 3 have laptops and no problems. (as far as we can tell)
so as far as folders deleted, only thing in any folder, is what we have created in the last 4 working days, which cant be much.
thanks for asking.
Message 20 of 23
RSomppi
I would start another thread instead of tagging onto someone else's mess. It only confuses things.
