Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit - Colabaration C4R Networks | Best practices
2 REPLIES 2
664 Views, 2 Replies
Hi Autodeskers,
I've been reading the other posts on the subject but I see nothing clear.
I'm interested in compiling best practices to collaborate on projects using Revit C4R (collaboration for revit) for a LAN and a WAN.
It will also be important to know your recommendations for the following settings:
-Projects top of 300MB (more tan 300mb)
-Team Work: 20-25 people
-Server With OS Windows Server 2003 R2 Standard Edition SP1
-HP Proliant ML110 G6, Intel Xeon Processor X3430 at 2.4GHz, 12/4 Gb RAM USABLE), 1 HDD 250 GB, Hard Drive 4 TB
What are the optimal requirements?
What is the recommendation to avoid network latency?
How the network is configured?
I appreciate your time and your comments
Thanks!
Roberto Tsuri
2 REPLIES 2
KyleB_Autodesk
@Anonymous wrote:
Hi Autodeskers,
Thanks!
Roberto Tsuri
Bandwidth is the primary consideration.  The machines running Revit should be able to ramp to at least 5Mbps symmetrical for burst transfers, but 15-20Mbps is optimal.  Our pre-fetching strategy reduces some of the dependency on bandwidth, but it's still the main consideration.
As for latency, we've done a good amount of work to reduce # of calls, in order to decrease sensitivity to latency in the duration of commands.  In general though, you're best avoiding a strategy to route cloud worksharing traffic through a proxy, and instead route it straight out to the open web for each LAN.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
in reply to: KyleB_Autodesk
Sorry for the late response, I was making several test, youre rigth, thanks Kyle
Technology Administrators
