Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2019 always crashes when sync model to 360 design
4 REPLIES 4
mvhC27KV
1814 Views, 4 Replies
Is anyone else having problems syncing to A360 design. Does not matter who is working on the project but all "members" can not sync. Every time you hit the "save to central" it saves locally (thank goodness). You then get the dreaded CER box that has no meaning what so ever.
When re-starting Revit 2019, a message asks if you want to open the model with your changes. Which you do and then you have a go at re-syncing, which becomes a game of chance. it may or may-not happen. You got to keep trying till it works. Frustration to say the least.
4 REPLIES 4
jay_miller1
in reply to: mvhC27KV
I have not experienced this, but just a thought - if it is a problem for all members it makes me wonder if the entire setup was corrupted.  Maybe start a new 'project' and transfer over your models.  If that doesn't work I would start looking at individual models to see whose might be corrupting the project.
Jay Miller
BHB Consulting Engineers, P.C.
mvhC27KV
in reply to: jay_miller1
Thanks Jay,
Will give that a try.
mvhC27KV
Jay,
Your solution seems to be working. Thanks for your thought.
Cheers
ptranbergNTI
Did you move the entire setup og did you troubleshoot one model?
Regards
Peter Tranberg
NTI A/S, Denmark
revitogbim.blogspot.com
