Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2018 convert to Revit 2016
2 REPLIES 2
kwilliams
2195 Views, 2 Replies
I am using revit 2018 for MEP.  The architects base model is in Revit 2016.  Should there be something I should be doing to interface with the model?
2 REPLIES 2
Revit_Whisperer
in reply to: kwilliams
Revit is not backward compatible.  You could link in their model and work successfully, but the architect won't be able to use your file.
All team members need to be on the same version, and ideally the same build of Revit for collaborating.
Hi @kwilliams
See also this article.
Rafal Gaweda
