Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2018.3 IMPORTANT ISSUE/BUG VG
1 REPLY 1
ambrosio.gomezC988N
572 Views, 1 Reply
Hi there,
I unsure if it is because Revit or the fact we are working on the cloud.
The issue is the following. When we are setting V.G-Link-Select link views after sync and close and open the file some of the links views are reset to host view.
It is in really important issue we are facing and a could not find a solution to this bug.
Is it another user who remove the links? No, it is not the case. I tested personally.
Is it because I press cancel? No, I don't press cancel.
Is the view link renamed? No, the link views are not renamed at all.
Thank you very much.
1 REPLY 1
Hi @ambrosio.gomezC988N
Just checking back on this issue.
Can you share a data-set to investigate further?
Please see: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
