Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2017 Properties dialog box issue
4 REPLIES 4
658 Views, 4 Replies
I just installed Revit 2017 and it seems the drop down arrows in the properties dialog box are not working ie to select a scale or model level etc.
I have done a search to no avail... can anyone shed some light on this issue?
// Erren
4 REPLIES 4
Revit_Whisperer
If a View Template is assigned to the view you cannot change items through the property dialog unless you set it to none.  You can also change the settings in the view template that will apply to all views with that view template assigned.
in reply to: Revit_Whisperer
Thanks, this doesn't seem to be the issue though, the properties options work perfectly in 2016 for the project, when importing the same project into 2017 it does not work. View template is set to <none> as suggested.
riccardo.evangelista7JHLC
My name is Riccardo. I am a Revit specialist.
Click HERE and please review carefully this article which contains a possible solution for your problem with Revit 2017.
Please let me know if this helps you to resolve the issue.
If I do not hear from you within 2 business days, I will archive the case. Despite of it, if you have any additional questions or concerns you can still post them here.
Best regards,
Riccardo Evangelista
Autodesk Support Team
Autodesk Revit Technical Support
Thanks Riccardo, I had my text/apps scaled to 150%, dropped to 100% and the issue is resolved.
Using a MacBook Pro (Retina) with a 27" Apple Cinema display running Windows 10.
// Erren
