Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2017 - not work
1 REPLY 1
giuseppemondola
246 Views, 1 Reply
Hi everyone,
I'm a italian student (sorry for my english) and I installed Revit 2017 with Educational license.
At the end of the installation software does not work (attached image of the dialog box). How can I fix the problem?
I have a laptop with the following specifications:
- ASUS i7-6700HQ
- Video card: NVidia GForce 960M (4 Gb dedicated)
- Ssd 516 Gb + Hard Disk 1 Tb
- 16 Gb RAM
Help me Smiley Sad
1 REPLY 1
@giuseppemondola
The first thing to point out here is that you have a gaming card.
That being case, update the driver by downloading it through the vendors site ( http://www.geforce.com/drivers )
If that doesn't help, try the following:
This should help get your application working. Assuming you have a valid serial number/contract.
  1. On your computer, navigate to:
    • ​​C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to
    • C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
When you start the application, it will Prompt you to choose one of the following:
  • Login - 30 day trial licenses
  • Serial Number - Standalone and Single-User activations
  • Network - Network License server for obtaining licenses from a machine on your network
Choose the option that matches your license.
NOTE: Students will always use the Serial Number option
If this information was helpful, please consider using the Accept Solution
