Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2017 not showing BIM360 Projects
1 REPLY 1
SCOTT.LEYBOURNE
674 Views, 1 Reply
Thanks in advance for any contributions
I currently have a BIM360 project set up and have files to be saved to the folders but when clicking collaborate in cloud I receive the message "you can not collaborate using the cloud because you do not have access to any cloud projects" I have noticed if i was to make a new project in fusion 360 teams that project would show up. Is there a way to switch Revit to look for BIM360 projects rather than fusion360 or is this not possible in Revit 2017? As a temporary work space I have manually saved the model as a central model on BIM360 by navigating through MYPC/BIM360/Projects but it doesn't allow other users to open the file correctly.
1 REPLY 1
Hello @SCOTT.LEYBOURNE , thank you for the question.
Revit cloud worksharing has two possible cloud locations BIM 360 Team or BIM 360 Document Management:
  • Revit 2018.2 and earlier models are stored on BIM 360 Team (this is similar to the Fusion Team service you mentioned)
  • Revit 2018.3 can store models on either BIM 360 Team or BIM 360 Document Management.
  • Revit 2019 and later models are stored on BIM 360 Document Management.
If you are looking to upload the model to BIM 360 Document Management, you could upgrade to a later Revit version (at least 2018.3).
If you don't want to upgrade the model, you would need to setup a BIM 360 Team project and upload the model there.
Lance Coffey
Technical Support Specialist
