Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2017 fails to print to PDF
218 REPLIES 218
Message 1 of 219
MattFried
97045 Views, 218 Replies
When i try to print to PDF the loading bar either freezes or doesn't start up at all, no pdf's being made. I mainly use "multiple selected views/sheets into a single file" option.
I tried the long route by creating seperate pdf files to combine after, but even some single pdf sheets aren't being made! I've lowered the resolution and all that as well with no solution. SOO FRUSTRATING, i can't send drawing sets to clients...
Every new version of Revit comes with new bugs and issues its very frustrating....
Please help.
218 REPLIES 218
Message 2 of 219
dzanta
in reply to: MattFried
Try doing a repair on Revit.
Try auditing your revit file
Try purging your revit file
Try deleting all data in your %temp% subfolder
Try exiting revit, then open revit prior to printing (clears cache)
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 219
river0013
I'm also having this issue printing to PDF.  Seems to get stuck mid process once the Create Adobe PDF box pops up.  Sometime is will let me work in Revit while the print window is open...so it thinks it's done printing?  I've also had it create the PDF, but the print window still stays open an acts like it's still working to create the PDF.  Sometimes restarting REvit does the trick.  Sometimes it seems like it might be related to file naming- tends to work better if I don't adjust name.  Really frustrating that a 2 min process can turn into a 1 hour process at times.  Issue has been with more than one project.
I'm using Revit 2017 with Adobe Acrobat DC.  I have zero problems with Revit 2016 and Adobe Acrobat DC, so I think the issue is with Revit 2017, not Adobe Acrobat DC.
Message 4 of 219
MattFried
in reply to: river0013
Seems like we have about the same issue..
A work around I've been using is to print with "CutePDF Writer" which seems to work, but I've never had to resort to using it until now.
And similar to you Revit 2015 and Adobe PDF work fine for me, so I assume its a problem with Revit 2017.
Message 5 of 219
fred.sobottka
Same issues as you guys.  I highly suspect that it is related to the changes in fonts they made in 2017.  Not sure why they couldn't leave well enough alone in this regard.  They changed how Revit sizes fonts.  Which is why many of my labels got out of whack. I have printing trougle and seems like my GSN has the most trougle as the page is mostly all text.  Arg!!!!
Did you guys find an solution other than the "CutePDF" solution. About to try that now.
Message 6 of 219
MattFried
in reply to: fred.sobottka
@fred.sobottka Other than trying a different PDF plotter, No i haven't found a solution...
Message 7 of 219
Had the same problem. It's the PDF driver. I switched to cutepdf and it works fine
Message 8 of 219
river0013
The issue seams to be related to the PDF file naming process.  In the Adobe PDF print properties there is an "Adobe PDF Output Folder" option.  When it is set as "Prompt for Adobe PDF Name" that is when the printing hangups happen.  If you change the output folder to a specific location, or default to Documents\ *.pdf, then it seems to print just fine.  I would prefer to use the "Prompt for Adobe PDF Name" as it has worked on all other versions of Revit and Adobe...without it a one-step process is now a three-step process (print to PDF, move to correct folder, rename) everytime I need to create a PDF and save it.  That really adds up when you create 10-20 PDF documents a day.
Message 9 of 219
chris
I run a print preview on one sheet, and then it will let you print multiple sheets.
I bit of a hassle but it works.
Message 10 of 219
MattFried
in reply to: chris
@chris Surprisingly this does work as a workaround. Thanks!
Message 11 of 219
When printing in Revit, go to Adobe PDF properties, uncheck box "rely on system fonts only, do not use document fonts".
Message 12 of 219
chris
Hi Eliseppa,
Unfortunately that fix does not work on my machine,
It will not even hold the setting?
Thank You,
Chris Blakemore
chris@deiengineers.com
Mailing:
4790 Caughlin Parkway #766
Reno, Nevada 89519-0907
Phone 775.329.2733
Fax 888.873.0790
Message 13 of 219
That didn't work for me either
Stephen H. Bronstein
Cornerstone Homes and Design, inc.
10032 Water Works Lane
Riverview, FL 33578
Steve@cornerstonehd.net
Voice 813-323-5781
FAX 813-641-2114
Message 14 of 219
ardentarchitects
Revit 2017 seems to have a real problem. Acrobat PDF seems to only work once after a reboot, then after killing the acrotray process I might get one more print out of it. Acrobat works fine in all other programs. I have installed CutePDF and NovaPDF both of them either take forever to print or they say they have printed and then when you go to the folder there is no PDF there. Both these PDF printers work fine in other programs.
The only PDF printer I have had reliably work is Microsoft PDF however it is limited by only going up to A3.
There is a serious problem with printing PDF in 2017.
Message 15 of 219
in reply to: ardentarchitects
Yep!
Message 16 of 219
Yes I'm having the same issue with 2017 and for some reason also with 2016.
I'm using Windows 10 with Adobe Acrobat Pro DC (clould version).
Only workaround is pointing the auto folder to document/*
Message 17 of 219
Zsolt.Varga
This incident has been reported to Autodesk and a resolution for it is being investigated for a future release of Autodesk Revit.
You find the current findings of the investigation in the following article in Autodesk Knowledge Network.
PDF output takes a long time or fails; progress bar stops advancing (Adobe PDF printer)
This article is going to be kept updated by the Autodesk Development Team.
In order to point other customers to this information source, I am going to go ahead and mark this post as Accepted Solution.
Best regards,
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
Message 18 of 219
thardy79
in reply to: Zsolt.Varga
I have this same issue. I have Adobe Acrobat Standard DC and I'm not convinced it is a solely a Revit issue as other co-workers use Revit 2017 as well, yet with Adobe Acrobat XI and it works fine.
Message 19 of 219
rick.kremer
in reply to: thardy79
Hey all,
Confirmed this with a customer, that when printing multiple sheets through Adobe PDF to the desktop, Revit does not hang or become "stuck" in creating PDF's. They did not have the Windows Anniversary ( Windows 10) or Windows 7 Update kb3177725
Plotting PDF's to the Desktop seems to be working on a Windows 7 machine, and on Windows 10.
***** If in Windows 10 using the Adobe PDF to print still gives you issues, download "CUTEPDF Writer" this application in Windows 10 will allow you to plot multiple sheets to the desktop without getting hung up"
Rick Kremer, Technical Consultant
Applied Software
Tags (2)
Message 20 of 219
thardy79
Was this trial done with Adobe DC? I have trouble with this when printing to Adobe DC which is the version of Adobe that is received when adobe is purchased now. You cannot revert back to the previous Adobe version.
Timothy Hardy
Structural Designer
Ædifica Case Engineering
796 Merus Court
St. Louis, MO 63026
T | 636.349.1600 ext. 265
F | 636.349.1730
E | thardy@aedifica.com
W | www.aedificacase.com
[cid:image001.png@01D190AA.E8F0CBB0] [cid:image002.png@01D190AA.E8F0CBB0] [cid:image003.png@01D190AA.E8F0CBB0]
