Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2017.1, A360 icon in open dialog now "BIM 360 Team"?
5 REPLIES 5
JADAstudio
773 Views, 5 Replies
It looks like the "A360" favorite icon in the open dialog has been changed to "BIM 360 Team". Is this indicative of larger changes coming to the C4R service? Will C4R users soon be required to purchase BIM 360 Team entitlements?
5 REPLIES 5
DarrenP
in reply to: JADAstudio
as far as i know nothing has changed except the name
DarrenP
scott_d_davis
A360 Team was renamed BIM 360 Team. You already have entitlements to BIM 360 Team with your C4R Purchase. There is no need to purchase BIM 360 Team for C4R, unless you need additional Team licenses for those that just need access to the Project Hub WITHOUT needing the Revit Worksharing capabilities.
Scott D Davis
Sr AEC Technical Specialist
JADAstudio
in reply to: scott_d_davis
Thanks, Scott. So is the A360 Team Hub (the web front-end for managing projects and participants) now "BIM 360 Team Hub" as well?
scott_d_davis
yes that is correct. C4R now falls under the BIM 360 platform, and this will open up a whole bunch of other possibilities soon!
Scott D Davis
But if the icon not appeae in the Open dialog box?, I already habe the last update of Revit. A360/bim team 360 or A360 Team.
In the website Team360 I can see the projects.
