Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Revit 2016 - a360 communications error
6 REPLIES 6
jeff.alberda
594 Views, 6 Replies
Good morning,
I'm having an issue with Revit 2016 A360 collaboration.
Everything was running smoothly until Thursday last week when I started getting this error. I have fully updated my revit to make sure that wasn't the problem. I was hoping it would be a general comminication error that would resolve itself but its still happening this week.
Attached are the logs and  config file.
Please help.
Thank-you
6 REPLIES 6
jeff.alberda
in reply to: jeff.alberda
I have noticed that it seems I no longer have that project listed under the projects shared with me. I have contacted the project manager to ask if they still see me listed.
Hi Jeff,
It do look like you got removed from that project and no longer have access to the C4R model.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
As in another post I read by Selene Akano from last year, the architectural rep says  "I can't seem to re add you for some reason:"
Any idea on something that needs to happen before I can be reinvited?  Its been 5 days I think since I last had access so I'm guessing its not time will fix it issue.
Contact the manager/moderator of the hub you are trying to access and check if you got removed for some reason or what the issue/problem might be when they try to add you again.
Lars-Ake Johansson
Sr. SQA Engineer
Is there a certain log file or anything besides an error message that might help if the invite fails again?
jeff.alberda
Well he was able to reinvite me so there is nothing to report.
