Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
REVIT 2015 - can't export IFC
1 REPLY 1
renatakuzma
347 Views, 1 Reply
I've tried to export an IFC file from a model which has only generic walls and windows, that happens to be a very small Revit file. Though, I can't export an IFC because it takes too long and, after that, there's an error. What could be happening?
Tags (3)
1 REPLY 1
Dear,
Try to download the Revit-IFC plugin.
It is found under below path:
https://apps.autodesk.com/RVT/en/Detail/Index?id=3754730560173591798&appLang=en&os=Win32_64
Kindly if this solved your issue mark as solution to help others.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
src="https://autodesk.widen.net/content/fbz0l2onhe/png/autodesk-expert-elite-forum-signature-logo.png" >
Mahmoud Zeidan
BIM Manager/Mechanical Engineer
