Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Render in Cloud - Error message
11 REPLIES 11
Message 1 of 12
any2094
462 Views, 11 Replies
Hi!
Im havig trouble rendering in cloud since thursday, its the first time this error message appears, and i can't solve it, eventhoug i follow the steps from the link autodesk provided to me (https://knowledge.autodesk.com/support/revit/troubleshooting/caas/CloudHelp/cloudhelp/2021/ENU/Revit...).
I have an educational membership, so credits ar not a problem
Its always the same error message i attach below WhatsApp Image 2022-03-08 at 5.26.37 PM.jpegWhatsApp Image 2022-03-08 at 4.22.54 PM.jpegWhatsApp Image 2022-03-08 at 2.54.13 PM.jpeg
11 REPLIES 11
Message 2 of 12
708Designs
in reply to: any2094
Make sure you are rendering to the allowed credit limits.
Message 3 of 12
Lance.Coffey
@any2094 There appears to be a (server side) issue with RPC content.
If you turn off the display of RPC content in the view being rendered (for example entourage and planting), does the view render successfully?
Lance Coffey
Technical Support Specialist
Message 4 of 12
any2094
in reply to: 708Designs
I have a educational account, so credits have no limits, thats not the pronlem unfortunatley
Message 5 of 12
any2094
in reply to: Lance.Coffey
Yes!!! Thank you very much, i was able to render the img with out RCP content!!
I have never had trouble with that before, it happend one day to another. Could the RCP familys be damage?? May be i should delete that folder and dowload it again. Do you have any suggestions?
Message 6 of 12
Lance.Coffey
The issue is on the server side (handling of the RPC content), not an issue with your model or families.
In the short term, I would suggest hiding the RPC content to allow rendering (if you don't have local rendering options to fall back on).
Lance Coffey
Message 7 of 12
708Designs
What is RCP content? In case this ever happens to me.
Message 8 of 12
Lance.Coffey
RPC (Rich Photorealistic Content) from ArchVision is a type of content that can be loaded into models through families. Some RPC content is included in the default library such as the people library as well as plantings and Entourage, additional content can be obtained through ArchVision.
The following help topic has more information on working with these types of families: Plants and Entourage
Lance Coffey
Message 9 of 12
708Designs
Thanks. I usually use Bimsmith or ENSCAPE content.
Message 10 of 12
any2094
Iy looks like that was the error, the problem was with the RCP content
Message 11 of 12
any2094
Today the server warns me that they are having problems with the RCP content, soy maybe this will happend to other people, now we know the solution, just turn off the display of RPC content!!WhatsApp Image 2022-03-09 at 9.22.14 AM.jpeg
Message 12 of 12
Lance.Coffey
@708Designs I’ve heard back on the server side issue, and it should be resolved as of 03/09/2022 (later in the day from when you saw the message).
Please let me know if you are still seeing issues rendering after turning the RPC content back on.
Lance Coffey
