Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
rename uploaded model
2 REPLIES 2
jagostinhoCT
523 Views, 2 Replies
hello,
Is it possible to rename an uploaded model to A360 C4R?
And if so, in case it is linked to other models, will the model name update?
Thank you
J
Assistant BIM/CAD Manager
Manchester, UK
Tags (4)
2 REPLIES 2
HI,
Yes, you can rename a C4R model in the "Manage A360 Models" dialog in the Collaborate tab.
It will update the name in any host models as well.
You will however see the 'old' name if you open the linked file but it will update the next time you do a Sync with Central.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
Lars,
I understand that after renaming the files on A360 from the Collaborate tab in Revit that the links will rename. However, does this rename the files on the A360 website?  I have tried renaming the files as described, and the name still shows up in my web browser.  I thought there may be a lag or that I needed to log out and log back in to the website but the old name still retains on the website.
Sincerely,
Andy Brack
Tags (2)
