Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Removed Cloud Revit Model, Still Reconizes the File, Can't Upload New
1 REPLY 1
tcalabrese
246 Views, 1 Reply
So I'm really new to Bim 360 Team. But figured how to Collaborate in Cloud (File open in Revit, used button). Then we received an updated file, so I thought I could open the new model, use the same button to update the Version.
Didn't work. Error message "There is already a Revit model with the same name....".
So next step I took was, login online to see if the file was somehow still there. - It doesn't show in the list.
Then back to Revit, try again to "Collaborate....".
Same error.
Does anyone know how correct this issue?
ps. I'm sure it's operator error.
1 REPLY 1
The file you see on the team site is only a 'published' version of the file, and not the central model.
To delete the central model you need to use the "Manage Cloud Models"-dialog. See more: Manage Revit Models in the Cloud
Regards
Lars-Ake Johansson
Sr. SQA Engineer
