Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Rebar Constraints Deactivate when Zooming Out
0 REPLIES 0
Message 1 of 1
jaclyn.squizzato
166 Views, 0 Replies
(This is one of the first times a colleague and I are modeling rebar.)
We have noticed that when placing rebar in slabs, the constraints and cover applied to that slab seem to deactivate when you zoom out of the view. This allows the rebar in a slab to accidentally be manually shifted outside of an applied cover.
We are manually sketching some rebar profiles, so I am wondering if the constraints are being deactivated in sketch mode and then are not able to be manually activated later? Is there a way to lock the cover / reactivate the constraints? Even when I go back into the constraints window I am not able to successfully modify them.
Hope someone may be able to assist,
Jaclyn
0 REPLIES 0
