Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
"Data in file *.rvt is corrupt needs to be manually recovered"
4 REPLIES 4
amandawynne3215
1076 Views, 4 Replies
We recently bought a new laptop to work on the Revit model at the jobsite.
After installing Revit and C4R 2016 and attempting to open the file, I get this message:
"Data in file SCVMC-SG-ARCH.rvt is corrupt and needs to be manually recovered."
Here's what we've tried so far:
-Cleared out the "Temp" cache to free up disk space (it's a brand new laptop so not really necessary but tried it anyway).
-Verified that we had the most up-to-date versions installed, as well as all service packs.
-All other users are able to open the model from A360, no error/corrupt message.
-User is able to open the model on another machine, no error message.
-Reinstalled Revit and C4R.
None of this seems to make a difference. Any ideas?
Laptop specs:
Model: ASUS K501UW
Processor: Intel Core i7-6500 CPU @ 2.50 GHz
Ram: 16.0 GB
System Type: 64 bit Operating System
Graphics Card: NVDIA GEFORCE GTX 960M
4 REPLIES 4
t_mokha
in reply to: amandawynne3215
Hello @amandawynne3215,
I see you're receiving a "The data in <file name> is corrupt and needs to be manually recovered" error just after opening a file shared through Collaboration for Revit in a new machine. All other users can open it properly.
Can you please attach a few journal files recorded when this error was presented?
Best regards,
__________________________
Adham Mokhtar
Technical Support Specialist
San José, Costa Rica
www.autodesk.com
amandawynne3215
in reply to: t_mokha
Please find the attached Journal Files from the laptop having the error.
t_mokha
Thank you.
Please look for the following folders:
Delete the local copy of the model in
C:\Users\avrp\AppData\Local\Autodesk\Revit\Autodesk Revit 2016\CollaborationCache\5JDYMZAJ8QQX\edb22d6a-1807-47a1-9b9e-a3eec8d20972\ c741086e-fe06-408c-aa6d-64dc1d0e6896
Delete the central cache file in
C:\Users\avrp\AppData\Local\Autodesk\Revit\Autodesk Revit 2016\CollaborationCache\5JDYMZAJ8QQX\edb22d6a-1807-47a1-9b9e-a3eec8d20972\CentralCache\c741086e-fe06-408c-aa6d-64dc1d0e6896
Delete the c741086e-fe06-408c-aa6d-64dc1d0e6896 folder located in:
C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\PacCache
Please also clear the %TMP% folder.
Let me know if you found these folders, deleted them and if the project file could be opened again.
Best regards,
Adham Mokhtar
www.autodesk.com
amandawynne3215
Perfect! This worked! Thanks 🙂
Tags (1)
Technology Administrators
