Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Quick Access Toolbar Glitch? | Option to Change the Ribbon to a Dark(er) Theme
3 REPLIES 3
RoyCF
693 Views, 3 Replies
System:
Operating System: Windows 10 Home Single Language 64-bit (10.0, Build 14393)
BIOS: 1.30
Processor: Intel (R) Core (TM) i7-6500U CPU @ 2.50GHz (4 CPUs), ~2.6GHz
Memory: 8192MB RAM
DirectX Version: DirectX 12
Display:
Name: Intel(R) HD Graphics 520
Approx. Total Memory: 4141 MB
Render:
Name: NVIDIA GeForce GTX 950M
Approx. Total Memory: 8078 MB
Question #2:
Will there an option to change the Ribbon to a darker theme? I set the UI to "Dark" theme but compared to AutoCAD and 3ds Max, it's still too bright for comfort.
Thanks in advance!
3 REPLIES 3
dzanta
in reply to: RoyCF
Double check your Revit build....I had this similar issue for the longest time.  I updated my Revit to the latest version and it corrected the problem.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
lars-ake.johansson
in reply to: dzanta
There is a couple of factors here that could influence this behavior (weird QAT):
1. Revit version/build. What version are you using?
2. Nvidia Optimus configuration.
You should make sure that Revit is using the correct GPU
1. Open the Nvidia Control Panel
2. Goto 'Manage 3D settings' "Program settings"
3. Make sure there is an entry for Revit.exe and that it's set to use the "High performance Nvidia processor"
This is something that is done automatically in the 'professional' (Quadro) graphics drives but is not set in the 'consumer grade' (GeForce) graphics.
4. Driver version.
This seems to pop up from time to time. You might want to check with your system vendor or on Nvidia.com for updated drivers.
I would start with checking the Nvidia Optimus settings.
If that doesn't help, make sure Revit (and any Addons like C4R) is up to date.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
RoyCF
in reply to: lars-ake.johansson
Thanks for the reply!
I tried adjusting the settings in Nvidia Control Panel and I think it solved the problem.
The toolbar is no longer a weird color and I think it matches the overall theme of Revit.
I have yet to update Revit to the latest updates since I just recently downloaded it.
