Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Publishing in Revit 2023
2 REPLIES 2
LRoe-FDP
225 Views, 2 Replies
The Publish function has been removed from with the Revit working model and is only available externally.
Pressing CTRL D to show that selection screen of Revit models, once changes are made, sync'd,  the publish setting is only available once I close out of Revit completely and reopen.  While I still have it open, the publish setting is greyed out.
Would Autodesk please bring back the Publish function from within the Revit working model?
2 REPLIES 2
Yien_Chao
in reply to: LRoe-FDP
just use the refresh button maybe? upper right corner. if your file have been changed, it will allow to be publish.
JAWilkinsonJBWAF
I may be wrong but I believe it has been replaced with using the Export/PDF, similar to exporting to CAD.
