Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
publish latest and exit Revit?
1 REPLY 1
Pshupe
1039 Views, 1 Reply
If it takes quite a while to publish, can you click publish latest and then immediately close Revit and it will complete the publish latest?  I would like to publish at the end of the day and then just leave, shutting down the machine.  Thanks
Regards Peter.
1 REPLY 1
dzanta
in reply to: Pshupe
from what I can tell, you can select Publish, let the window state that you can continue working while publishing is happening, save your work and close Revit.  The updated published model will show up in your Project Hub....look at the date and version number to verify.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
