Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Projects not showing in Team hub
5 REPLIES 5
shawnphillips
291 Views, 5 Replies
Using Revit we uploaded projects to A360.  When we go into the A360 Project Team Hub the projects do not show up.  I selected 3D views (Views in A360) and saved to central then published.  They should be there.  I see a note on Autodesk saying they are having cloud storage issues but I wanted to verify that the process I am following is correct and that this is likely just their online issues of the day.
5 REPLIES 5
chubbard
in reply to: shawnphillips
We are also not seeing our models that are on C4R publishing to A360.  I have synce, published waited about 14 hours still not showing on A60
Ours showed up this morning. Guessing ADesk had an issue with their servers yesterday. Working now.
chubbard
I figured that after the slew of emails over the weekend, but still not showing on A360 right now. I even re-published the file from Revit.  C4R thinks its published but A360 does not show
We are still experiencing issues with A360 Team and that includes publishing of C4R models to the hub and are working on a solution to the issue
Please see the health page for more details and updates when the problem is solved.
https://health.autodesk.com/
Sorry for the inconvenient.
Regards
Lars-Ake Johansson
Sr. SQA Engineer
shawnphillips
in reply to: chubbard
Looks like ADesk has acknowledged that there might still be a problem but in the meantime, make sure you are designating at least one view (sheet or model) in the "Views for A360" tab for your projects. Just a thought though I suspect once the issues at Autodesk are worked out your problems will disappear.
