problems with linked model from cloud
xu.teng
xu.teng
i have revit model with linked mep and interior file from cloud, but after a couple of day, the linked path will turn from cloud to my local drive, can anyone tell me how to fix this problem? i was trying to delete these linked files and insert them again, but the problem comes back after a couple of days.
sasha.crotty
Hi @xu.teng ,
This issue has been fixed in Revit 2019.2.3, 2020.2.3, 2021.1.1, and Revit 2022. Please update to the latest update release for your version to avoid this issue.
Sasha
Sasha Crotty
Director, AEC Design Data
xu.teng
we are all using revit 2019.2.3.
xu.teng
does anyone know how to solve the problem?
sasha.crotty
Here's what our development team suggests:
  • Triple check that every team member is on the same updated version. Just one person on a different version can cause this issue to come back for everyone.
  • It may be possible that a link is already in a bad state.   We suggest using "reload from" and pointing to the same RCW link to make sure that any bad state has been cleared, for all links.
  • One other recommendation is to clear any per-user unloading link overrides (unload for me) and all users sync with central.  After that, create new local files and hopefully you won't see this again.
If you try these and to do keep seeing an issue I recommend filing a case with Autodesk support.
Sasha
Sasha Crotty
xu.teng
thank you for your reply. I follows your steps to check all the things, and tried to link from my computer, it failed. The weird thing is that my coworker did it successfully without any problem until now.
