Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Preparing.rvt for viewing hangs....
1 REPLY 1
b.gorkom
315 Views, 1 Reply
I've got a problem with BIM306team.
We had a free Team-Hub (60day )  and turned it today into one with a license (C4R 4 users) + BIM360team 25 users)
After assigning the contract-number to the hub using the contract manager, the following problem occurs:
We opened the model in Revit.
We published the model to the cloud, then:
The views keep preparing instead of showing them.
I still can synchronize the model in the cloud
We tried the following the following procedure:
- We downloaded the model from the cloud to local
- We deleted the model in the cloud using Manage Cloud Models (in Revit)
- We opened the downloaded model and saved it back to the cloud
- The Sheets we wanted to publish were still selected in the Publish Settings
- We published the model using Manage Cloud Models
- Then same same issue reoccurs...
The problem described above did't happen in the free version of BIM360team
It worked all quite well...
1 REPLY 1
b.gorkom
in reply to: b.gorkom
It took a long time for preparing views when you migrate from free to subscription.
The next day the views were all visible.
