Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Personal accelerator for C4R2016 update failed
1 REPLY 1
benno.toorn
844 Views, 1 Reply
I got the update 'Personal Accelerator for Autodesk A360 Collaboration for Revit 2016 English-US Unlocked 64-bit' in de Autodesk Desktop App. When I click on update it says that already another version is installed. The only other version is C4R2016 v5.
After I've uninstalled C4R2016 with the uninstall tool, the 'personal accelerator' update will be replaced by the v5 update. When I install the v5 again I got the 'personal accellerator' update back in the list. When I try to install that version  the same problem occurs.
What is causing this and how can I fix it?
1 REPLY 1
huotger
in reply to: benno.toorn
benno.toorn,
Thank you for mentioning the complications you have encountered.  We have removed both the Collaboration for Revit 2016 v5 update and companion application Personal Accelerator from the Autodesk Desktop Application and Accounts portal while we address these errant messages.  In the meantime, please refer to the direct download at: Autodesk A360 Collaboration for Revit 2016
Sorry for the inconvince,
Gerry
Gerry Huot
SQA Manager
