Announcements
Parameter Services - Properties Pallet Group not updating
aflamishS9HNH
aflamishS9HNH
Case# 21025444
Inside the Parameter Services feature, I have an issue where my Properties Palette Group is not updating parameters added through a shared parameters file. The ones I make with the parameter service are just fine. Nevertheless, I found a workaround. So long as you adjust the "type or instance" setting first, and then change the Properties Pallete Group, it will accept the change. Afterward, put the type or instance setting back to the original selection. It is a strange workaround, but at least my changes are being saved until the Autodesk team can get in there and fix the code.
Replies (0)
