Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Not all BIM 360 Team projects / folders visible in Revit until restart
21 REPLIES 21
Message 1 of 22
JADAstudio
1238 Views, 21 Replies
I have an ongoing issue that has survived a complete re-install of Windows 10 and Revit.
When I first start my computer in the morning, launch Revit, and click the BIM 360 Team icon in the File>Open dialog I only see C4R projects that are hosted on others' team hubs; I do not see projects that are hosted on my hub. However, I can open recent projects that are hosted on my hub from the recent projects list.
Once I restart the computer the problem goes away and I can see all of the projects.
Any ideas what could be happening here or how to troubleshoot or fix this?
21 REPLIES 21
Message 2 of 22
JADAstudio
in reply to: JADAstudio
A colleague (someone I've invited to many of my projects as a "project contributor") mentioned to me today that sometimes he can't see my projects either and a restart usually fixes it for him. He can see his BIM 360 Team projects just fine but mine disappear occasionally.
This leads me to believe the issue is not local to any one computer but has something to do with my BIM 360 Team hub and/or Autodesk account.
I'm in touch with Autodesk support; hopefully we can find the root cause and fix it.
Message 3 of 22
This may be a matter of Revit version. There is no cross-over. So Revit 2017 projects won’t appear when in Revit 2016.  And Revit 2016 projects won’t appear in Revit 2017.
This article may be helpful too: Collaboration for Revit: Projects on A360 do not show up in Revit
Does that sound like what’s going on? Or does it appear to be something else?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
Message 4 of 22
These are all 2017 projects. Sometimes they appear in the 2017 File>Open browser and sometimes they don't, for both me and a remote contributor. So far all that is required is a restart to get the projects to appear.
Message 5 of 22
AdamPeter
If/when this happens again would you be willing to post a journal that captures the attempt?
Adam Peter
Customer Program Manager
Message 6 of 22
JADAstudio
in reply to: AdamPeter
Journal files attached.
Message 7 of 22
AdamPeter
Thanks for posting @JADAstudio I'll take a look.
Adam Peter
Message 8 of 22
AdamPeter
@JADAstudio after investigating it looks like there is a timeout on the call to the hub with those projects.  I believe this is transient in nature and if you simply close the open dialog and wait a minute and reopen it will show the projects (your reboot of the machine coincidentally is enough time to try again, but I don't believe this is required).  If you continue to struggle with it please message me directly and I can investigate further.
thanks,
Adam Peter
Message 9 of 22
JADAstudio
Thanks, Adam.
Is there anything I can do on my end to eliminate the root cause of the timeout?
Also, why would the timeout only affect the projects hosted on my hub and not those hosted on others' hubs?
Message 10 of 22
AdamPeter
When you access the open dialog and click the BIM 360 Team icon we basically make a call to each hub that you are a member of for it's list of projects you have access to.  It appears from the journal you posted and some digging in the back end that for whatever reason the call to that particular hub was longer than normal and thus timed out and returned no projects for just that hub.  There's nothing you can really do to eliminate the timeout because its a call from one of our services to another.  It shouldn't take so long that it times out so we'll continue to look into that part on the back end.  In the meantime, just close and re-open the dialog and let me know in the next day or two how often it happens in a day so we can get a better handle on the frequency.
Adam Peter
Message 11 of 22
JADAstudio
Here is my log for the day (so far):
all times are Pacific
"fail" = only shows projects in others' hubs in the File>Open>BIM 360 Team dialog
"succeed" = shows all projects including those in my hub
05:46 - fail
05:48 - succeed
09:21 - fail
09:22 - succeed
09:54 - succeed
10:42 - fail
10:42 - fail (after sync-with-central to project hosted on my hub)
13:31 - fail (after long lunch away-from-keyboard)
14:18 - succeed
14:24 - succeed
14:37 - fail
15:04 - succeed
16:54 - succeed
19:43 - fail (after long AFK)
20:53 - fail
20:54 - succeed
21:21 - succeed
21:26 - succeed
Message 12 of 22
AdamPeter
thanks @JADAstudio, this information will help us narrow down exactly what's happening.  Obviously this isn't just transient and well work to find a resolution as quickly as possible.
Adam Peter
Message 13 of 22
AdamPeter
Hello @JADAstudio, sorry for the delay in getting back to you.  I was wondering if you could private message me a wider scope of journals if this is still happening.  It would be great if we could get several days worth, especially if it's happening with the same frequency as you mention above.
thanks,
Adam Peter
Message 14 of 22
JADAstudio
No worries, will do.
I don't usually make that many trips to the file>open dialog in one day. I'll test the file>open dialog more frequently over the next few days and PM you log files early next week, if that's ok.
Message 15 of 22
Hi guys,
I'm having the same problem as @JADAstudio. But a restart of Revit or waiting a few minutes to reopen the Open dialogbox doesn't solve the problem for me.
I can reach the project with an internet browser or open them in Revit using 'Recent Documents', but not through the Open dialogbox.
I can send some printscreens if necessary.
I'm working with Revit 2017.2 and the project is also started in Revit version 2017.
Message 16 of 22
Dear,
Can someone help me with the problem that also is reported by @JADAstudio in this post: https://forums.autodesk.com/t5/revit-collaboration-forum/not-all-bim-360-team-projects-folders-visib...?
Message 17 of 22
Can you post or send me a journal file so I can see if it's the same issue as baumbach?  If we can find a specific patter it will certainly help us identify a solution.
thanks,
Adam Peter
Message 18 of 22
Hi @AdamPeter, Attached you find my journal and dump file.
Message 19 of 22
Thanks @joris.vanbossche.  Are you a member of multiple hubs or just one?  Also are you getting the "you are not a member of any BIM 360 Team projects" every time or just periodically?  The journal makes it seem persistent, but just wanted to double check.  You also mentioned that you can open models from this project from your recent history.  Does this mean that it was working for you previously and recently lost the ability to access or has this never worked for you?
Adam Peter
Message 20 of 22
Hi @AdamPeter,
- I'm member of multiple hub's
- I've this problem all the time since last Friday. Before I didn't had this problem
