No Project Browser and Revit Properties - View Appears
Good Estimates
Eh I had the problem that the Project Browser and Properties palettes did not appear, nor by the view tab which I did the following myself to solve it:
Regedit Method
1.-press the Windows keyboard symbol + R.
2.-In the execute box you have to write: regedit
3.-Inside the log editor press F3 (that would be search), and you type: ProjectBrowser, and press Find Next.
4.-In the right column of the registry editor you must delete from the list ProjectBrowser and PropertiesPalette
5.-You start revit again and ready, the bars are reset and appear normally.
Graphic Resolution Method
1.- On your Desktop right click and you go Screen Resolution
2.- within the window located Resolution
3.- Choose a lower resolution than the one you are currently in. See Example 3.1
4.- Once you find the Project Browser palette and Properties, return to the resolution you had at the beginning.
3.1.-Example:
we see in the image a resolution 1920x1080 which we are going to download it 1280x960, you have to go testing with different resolutions
you have to try them all until you see that the Project Browser and Properties palettes appear, remember that these palettes must be activated in the view - User Interface tab.
