Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
My Local file opens everytime I try to open my Central model
1 REPLY 1
nrmnfstr123
279 Views, 1 Reply
My file is saved in BIM360 and is being worked on collaboratively. When I try and open it, through BIM360, it opens the local file rather than the central cloud model. I am SO lost as to how to get rid of my local file and access the file that is being collaborated on and shared on the cloud. ? Any help will be greatly appreciated.
This local file checkbox is meant to be greyed out...
1 REPLY 1
Lance.Coffey
in reply to: nrmnfstr123
Thank you for the question @nrmnfstr123!
It sounds like you may be accessing the cloud model through the Desktop Connector:
If you are working with Revit 2019.1 or later, try going to the Revit Home, and accessing your cloud project/model there.
Note: The option to open cloud models was removed from the open dialog with version 2020 and later, in these versions the only option is to use Revit Home.
Lance Coffey
Technical Support Specialist
