Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Missing missing external cloud Revit!! pls help me T-T
8 REPLIES 8
Message 1 of 9
nuttpanu
190 Views, 8 Replies
8 REPLIES 8
Message 2 of 9
Yien_Chao
in reply to: nuttpanu
are you trying to link a cloud file to non cloud project? that wont work
Message 3 of 9
nuttpanu
in reply to: Yien_Chao
I open file like this.
and then i want to link file from cloud
missing i con external cloud. T-T
Message 4 of 9
Are you trying to insert link via Insert > Manage Links?  Try insert link via Insert > Link Revit.
Message 5 of 9
nuttpanu
in reply to: ToanDN
I try both but not work.
Message 6 of 9
Lance.Coffey
I could see a few things that could cause this behavior.
  1. Check that Revit is updated to the latest build (2022.1.2), to avoid this issue: "The publisher of this add-in could not be verified" for CollaborateDB when starting Revit
  2. Verify that the Autodesk.Collaborate.addin exists in the folder C:\ProgramData\Autodesk\Revit\Addins\2022.
    1. If missing, use the following article for info on How to reinstall the Revit Cloud Worksharing Add-in
  3. If you have add-ins loaded into Revit, try disabling them, as I've seen add-ins interfering with the cloud functions.
If none of these steps work, could you attach a journal recorded when trying to link?
Lance Coffey
Technical Support Specialist
Message 7 of 9
Yien_Chao
are your link all central file on cloud? i think i wont work otherwise.
Message 8 of 9
nuttpanu
in reply to: Lance.Coffey
When i open file linked. What is add in Revit request?
Message 9 of 9
Lance.Coffey
From what I'm seeing in the screenshot, I would expect this would be either the Collaborate add-in, or Desktop Connector service (missing).
Lance Coffey
