Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
missing collaborate button
2 REPLIES 2
MJAIT
2152 Views, 2 Replies
Can someone help with this?
I don't have "Collaborate" button on any of my Revit products. what could be reason. and what is the solution?
Thank you,
2 REPLIES 2
tdaniel
in reply to: MJAIT
  1. Reset the Revit User Interface by deleting the UIState.dat file in the location below:
    %APPDATA%\Autodesk\Revit\ <Revit Version> 2015
  2. If that doesn't work you may have to reinstall C4R
  3. In some cases 1 & 2 didn't work for me so I had to use the clean uninstall procedure and then reinstall the Revit.
in reply to: tdaniel
I had this issue beforte and realized that depends on the Revit Version you are using the collaborate button might appear before or after making a model central. In 2018, collaborate button appears before, in 2014 on the other hand the button appears after worksharing and centralizing model.
