Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
material library with update notice
1 REPLY 1
marcosfigcantanhede
518 Views, 1 Reply
In the materials window at revit a warning sign appears in some materials, I found an individual update video of each material with this sign, how can I update them all at the same time? It's possible?
1 REPLY 1
Hello @marcosfigcantanhede welcome to the Autodesk forums, and thank you for the question!
I found the following article related to the alert message you are seeing:
"For improved rendering, replace the current appearance asset in this material with a newer version”...
This message is being displayed to let you know about the option of updating your materials with new physically-based asset definitions. The update is optional, and there may not be new assets for all of the materials that you have setup.
I’m not aware of an automated way to update the material assets within Revit.
Lance Coffey
Technical Support Specialist
