Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Linked model will not stay room bounding
73 REPLIES 73
Message 1 of 74
tthor
8989 Views, 73 Replies
I have a linked structural model which will not stay room bounding.  The link type parameter has the "room bounding" box checked but the link does not properly bound the rooms.  The individual elements within the linked model also show the "room bounding" parameter box checked.  We are constantly getting warnings that rooms are in the same enclosed region or not enclosed due to columns and foundation walls losing the bounding properties.
We can edit the link room bounding parameter by toggling it off/on to reset the bounding properties, but this is only a temporary fix.  Periodically it will lose the room bounding during synchronizing or reload latest.  I've since removed and reloaded the linked model, but this only temporarily fixed the problem similar to toggling the room bounding box on/off.
We recently upgraded from Revit 2016 to 2017 in C4R which is when this issues started.
Does anyone know of a fix for this issue?  Any thoughts on what might be causing it?
Thank you,
Tim
73 REPLIES 73
Message 61 of 74
RSomppi
in reply to: JF.K
Is this link being updated prior to the room bounding being turned off? Any clues as to what is being done in your model prior to it being turned off?
Message 62 of 74
JF.K
in reply to: RSomppi
@RSomppithank you for the reply.
The linked model is not being updated actively since the advisor's model is linked from Docs and it isn't Cloud Workshared. For this specific project we use it as one cloud use Dropbox. The advisor has access to our ACC environment through Docs and updates it weekly. On our side we reload the model to see its updated state.
Yes, as soon as someone synchronizes (or reloads latest) the problem arises and synchronization doesn't work.
If I check ACC at the moment of synchronization, the linked model gets locked for 1 second and then automatically unlocks. Then I need to:
  1. select OK or Cancel
  2. Re-synch
  3. After synch is done, the user has to select the linked revit model and do the ON/OFF workaround. This way the linked model is seen as room bounding again.
Every time someone synchronizes this happens which is extremely annoying.
I also noticed earlier that the linked model sometimes gets permanently locked and I need to unlock it manually from AAC.
Message 63 of 74
RSomppi
in reply to: tthor
Is the name of the link changing with the update process?
Message 64 of 74
JF.K
Assuming you are answering to my post:
No, that's a no-go within our BIM process. We keep the model names as they are setup from the beginning. If names need to change, then new models need to be uploaded from scratch since BIM360/ACC handles model renaming very poorly.
Message 65 of 74
RSomppi
in reply to: JF.K
I think the problem is with the update process. The above sentences don't make sense and are confusing. Can you clarify?
Message 66 of 74
RSomppi
in reply to: JF.K
That's only because renaming a model doesn't break the link to it. It is by design and for very good reason.
Message 67 of 74
JF.K
Ok let me try to clarify then.
The way we link the advisor model is described by the following link (option 2): "To link in other Revit models from Docs that aren't Cloud Workshared"
When we synchronize, the problem which I described above with pictures and bullet points starts.
On top of everything, sometimes one of the users locks automatically the linked advisor model for no apparent reason.
I agree with you about the source of the problem. Maybe I need to go step by step with the advisor to see how he/she uploads the model into our ACC platform. Meanwhile I opened a ticket to the autodesk support team. If there is a solution for this issue I will post it here so that someone else can benefit from it.
Message 68 of 74
RSomppi
in reply to: JF.K
My workflow when updating links is to rename the existing one and upload the new one with the appropriate existing name. Revit "follows" the renamed old link. Then I "Reload From" and target the updated model. Only after reloading, is it safe to delete the old model. If this process is not followed, Revit will think you are linking to a new model.
I use workshared cloud models for linking even if the consultant (Advisor) is sending us updates. This has been working for many projects. Having the links as workshared projects prevents unloading when one is opened.
Message 69 of 74
JF.K
@RSomppi  thank you for your input.
Normally, when using ACC/BIM360 either the whole team works in one cloud environment or we use bridge to connect different clouds.
When using ACC/BIM360 as a container for dropping 3rd party models (advisors) it seems that the setup needs to be done differently. If this is indeed an upload problem, your workflow should be the answer to our issues.
I will keep you posted.
Message 70 of 74
akhilanandBF7QN
in reply to: tthor
Informative 👏.
Message 71 of 74
akhilanandBF7QN
in reply to: tthor
Informative ‌‌.
Message 72 of 74
JF.K
Thank you for the suggestion. It worked quite well for us, although a bit of work is needed in order to update the model successfully.
Message 73 of 74
allan_mentzingen
in reply to: tthor
About the locking / unlocking file issue: I think that happens with any Cloud model that is not a Workshared Cloud Model. So, that means that only one person can edit it at a time. That's why ACC automatically locks and unlocks the files every time someone access it... It doesn't mean that the person is manually locking and unlocking it. If the file was a Workshared Cloud Model - which can only be enabled via the "Collaborate" tab in Revit - then this would not happen. Just remember that since BIM360 / ACC have been introduced, "Worksharing" has got a different meaning. It differs from the traditional working method of "Collaborating" locally (with Worksets enabled). When we save this type of model to the Cloud (either by dragging and dropping to the ACC via browser or by using the "upload" button there), it is just a Cloud model. Not workshared. You can only make a model "Workshared" via Revit itself. So having worksets enabled in the model does not mean the file is Workshared. It can still be just a cloud model (originated from a central file with worksets enabled for local collab).
Workshared models have the following symbol after their filenames on ACC. Otherwise, they're just cloud models.
Another way of finding out if your file is either a cloud (non-workshared) or a workshared cloud model is via Revit Home, under Autodesk Projects, while Projects List View is enabled:
Message 74 of 74
f_nibte_HR
in reply to: JF.K
We are also still experiencing intermittent loss of the shell model's room bounding ability R23/R24 especially when working with more than 1 person in the same model.
