Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Is BIM 360 Down?
4 REPLIES 4
chad.hilkeKFSLK
1147 Views, 4 Replies
Is BIM 360 Down?
We have been unable to open any BIM360 projects since Sunday. Is this problem on our end, or is BIM 360 down? The only problem reported on the health dashboard is with BIM 360 Account Administration. Thanks.
4 REPLIES 4
Hello @chad.hilkeKFSLK .
I'll be happy to help.  Are you still having this problem?
This issue can have many possible causes.   Does the problem happen on another computer using the same login?
Does the issue happen for any user on your network?
This article may help to narrow down the cause.
"You do not currently have access to Autodesk Collaboration for Revit" when opening a workshared mod...
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Michael C
We found the problem. Our licenses were expired. Our parent company has a portal that they use to keep track of our licenses, but for some reason it did not notify them that our licenses were set to expire, and our department was not notified until we could not access BIM 360. This has since been rectified. They are working with Autodesk to see why this information was not included in the portal. Thanks.
I'm happy to hear this has been solved.   I'll mark your post as an accepted solution.
Thank you!
Michael C
