Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Insert View from file - A360 Collaborate files
10 REPLIES 10
Message 1 of 11
andrewrider
2702 Views, 10 Replies
When using C4R we are not able to insert content from views that are on A360. Is there a work around for this? I know you could download the project to your computer but this would be a waste of time.
10 REPLIES 10
Message 2 of 11
alan.quinn
in reply to: andrewrider
I understand that you are trying to insert views from a file hosted on A360, but do not see those as location options in the dialog. This is a current limitation of A360 that development is aware of and is looking into ways of addressing. As you pointed out the only work-a-round is to create a copy of the file you wish to insert views from either on a regular network share, or on the local drive, and insert the views from there.
I wish I could offer more but unfortunately I cannot. I have however attached your case to the internally logged development case. Please let me know if you have additional questions or comments and thanks for posting.
Message 3 of 11
robert.spink
in reply to: alan.quinn
Any update on this yet?
Message 4 of 11
dbrokaw
in reply to: robert.spink
Any updates on this Autodesk team?
Message 5 of 11
EricSSchulz
IMHO, this basic A360-A360 view insert capability is overdue...
Message 6 of 11
andrewrider
in reply to: EricSSchulz
The new Desktop connector application might be a way to accomplish this....Although right now it looks like you are only able to insert from items that have been published to your BIM360 Team site. So still no direct connection to the C4R project files but its better than what we had before.
Message 7 of 11
EricSSchulz
For the immediate term, we are simply:
1. Opening both A360 Projects in the same session.
2. Creating blank views in the destination project that are similar to the ones desired from the source project
3. Copy / pasting vector / text / 2D elements between files
Low tech and fast for now...
Message 8 of 11
bnovotny
Has this been fixed yet on either C4R or BIM 360?
Message 9 of 11
Very Low tech as i have multiple legends that i would like to pull across at once
Message 10 of 11
rosterfeld
How do you insert from a published file?
Message 11 of 11
archie.manza
You will be able to do this using BIM 360 connector
https://www.autodesk.com/bim-360/desktop-connector/
