Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Import files
6 REPLIES 6
mohamadhamed833
289 Views, 6 Replies
Import files
How can I link the database files of the Revit training course that are related to version 2022 in version 2023 without changes.
Thank you for your reply
6 REPLIES 6
RSomppi
in reply to: mohamadhamed833
You can only temporarily link them without changing the files. They still need to be upgraded to link them but Revit will do this without changing the original file. I would not do this,
Instead, upgrade a copy of the files.
mohamadhamed833
in reply to: RSomppi
Hello, thank you for your answer
I did not quite understand what you meant. The difference between the two versions can be clearly seen in the two images below. I suspected that maybe the settings and filters are different in my version. Are you saying that I must have the 2022 version on my device? Or are you telling me to open a copy of the original file in version 2023? That's what I did, in which case the changes will be even more
best regards
RSomppi
Those differences are only in the view settings, if it is the same file. Upgrading a file does not cause that kind of thing. It is a copy of the same project.
Use 2022 or upgrade all the files to 2023. There are probably some differences in the interface but the models will not change.
There is no change.  Your view is wireframe and the video snapshot is showing a realistic view.  Change your view to realistic then they look the same
Toan Nguyen
mohamadhamed833
all right, I got it. I appreciate your reply
best wishes
mohamadhamed833
in reply to: ToanDN
Thanks a lot
best wishes
Technology Administrators
