Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
IFC content in Revit - is these a way to hide the facet lines
1 REPLY 1
dgmcchesney
525 Views, 1 Reply
Is there a way to 'hide' the facet lines of IFC elements within Revit?
Ultimately I would like to show this IFC content on a sheet and I do not want to have the lines visible.
Any ideas?
1 REPLY 1
RDAOU
in reply to: dgmcchesney
@dgmcchesney
From which application/software did you export/convert to IFC? And are you able to TAB select the offending lines separately/individually in Revit? if not; you need to go back and clean them up before you convert to IFC
Once in IFC it's just a data model. Not as flexible as one might wish it to be
