Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
i ran the revit update and can longer manage a360 files.
4 REPLIES 4
russpittman
316 Views, 4 Replies
4 REPLIES 4
DanFaba
in reply to: russpittman
Hello, Russ
Which update did you run? Can you try to roll it back?
Dan Faba
Autodesk Revit Technical Support
With the latest updates of both 2016 and 2017, you must install both the Revit update and the C4R update to make everything work properly.
If you only install the Revit update, the Manage cloud models dialog will not work properly.
The C4R update should be available in the Desktop App or on the website;
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-bim-...
Regards
Lars-Ake Johansson
Sr. SQA Engineer
russpittman
in reply to: DanFaba
It was on the Autodesk app for Revit 2016. I'm not sure and it doesn'[t say
Easiest way would be to download and run the separate installer for Collaboration for Revit with the following link:
This should install the latest version of C4R (and any other updates that isn't installed)
Regards
Lars-Ake Johansson
Sr. SQA Engineer
