Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
How to use the "label all" function to add the label "height offset from the floor" on all floors / 如何使用「全部加上標籤」功能,在所有樓板上加上「距離樓程高度偏移」的標籤
2 REPLIES 2
778 Views, 2 Replies
How to use the "label all" function to add the label "Height Offset from Floor" to all floors.The problem currently encountered is that there is no option for "Height Offset from Floor" in "Edit Label" in "Floor Label Template File".
Can you find it or other ways to replace it, and complete the labeling target of "height offset from floor height" for all floors at once.
如何使用「全部加上標籤」功能,在所有樓板上加上「距離樓程高度偏移」的標籤。
目前遇到的問題是 在「樓層標籤樣板檔」中的「編輯標示」,裡找不到「距離樓程高度偏移」的選項。
有沒有可以找到它或是其他辦法可以取代他,完成一次為所有樓板加上「距離樓程高度偏移」的標籤目標。
Labels (3)
2 REPLIES 2
JM_K
Inside the Tag Family, create a Label that reports "Elevation at Top" (or pick the part of the Floor's height that you want to report). That will report the height offset (from it's constraining Level) parameter of the Floor in the Project:
Insert witty comment here.
JM_K
in reply to: JM_K
Set this Tag as the default Tag for the Floor Category:
And then you'll be able to use the Tag to "Tag all".
Technology Administrators
