How to Change a Project Thumbnail Setting Preview on C4R (No Save As Option)?
Ali_Entezami
Ali_Entezami
Hi Guys:
I'm working on a project stored on C4R with limited authority to re-write or delete the central file.
Wondering if there is another way than the "Option" on save as dialog-box to change the project thumbnail preview image?
I need to change it to our company disclaimer view.
Thank You
Ali
do you mean the starting view?
Ali_Entezami
Hi arjay.eco I am talking about the Thumbnail on Revit opening page, before you open any file.
Jacob.westergaard
Autodesk Support
Autodesk Support
Hi Ali,
Thank you for taking your time to post this on the forum,
The thumbnail you have set when you make the initial upload will be the one associated to the file.
So whatever thumbnail you want to have will need to be set before you upload it - if you want to change it afterwards I assume the only way is to re-upload it with the desired thumbnail.
Thanks again,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Ali_Entezami
Jacob,
Thank you,
Yes I'm aware of this, as I explained I have limited access and no right to delete or re-write or re-upload the central. I was wishing should be another solution for that.
Ali
