Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
How to Change a Project Thumbnail Setting Preview on C4R (No Save As Option)?
4 REPLIES 4
Ali.Entezami
756 Views, 4 Replies
Hi Guys:
I'm working on a project stored on C4R with limited authority to re-write or delete the central file.
Wondering if there is another way than the "Option" on save as dialog-box to change the project thumbnail preview image?
I need to change it to our company disclaimer view.
Thank You
Ali
4 REPLIES 4
in reply to: Ali.Entezami
do you mean the starting view?
Ali.Entezami
Hi arjay.eco I am talking about the Thumbnail on Revit opening page, before you open any file.
Tags (1)
Hi Ali,
Thank you for taking your time to post this on the forum,
The thumbnail you have set when you make the initial upload will be the one associated to the file.
So whatever thumbnail you want to have will need to be set before you upload it - if you want to change it afterwards I assume the only way is to re-upload it with the desired thumbnail.
Thanks again,
Jacob Westergaard
Autodesk Premium Support Team
AEC Premium Support Services
Jacob,
Thank you,
Yes I'm aware of this, as I explained I have limited access and no right to delete or re-write or re-upload the central. I was wishing should be another solution for that.
Ali
Tags (1)
