Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
HOW I FIX REVIT ACCELERATO << INTERNAL APPLICATION ERROR>>
1 REPLY 1
266 Views, 1 Reply
HOW I FIX THIS ERROR.
FOR A COLLABORATIVE WORK
Tags (1)
1 REPLY 1
Lance.Coffey
First, check if the following article applies:
Revit Server: Can’t set accelerator within Revit
Next, try using the IP address of the accelerator (instead of the host name).
If this doesn't work, verify that the system can ping the accelerator as well as the host server. To check DNS make sure that if you ping the IP address with the –a switch that it returns the correct host name (the IP address and host name should remain the same throughout the Revit Server network).
Lance Coffey
Technical Support Specialist
